Simple security problem
Gabritex
Visitor
I have this config but kids with Kali can enter in the Aironet and access admin network. What im doing wrong? Is any way of resolve issue withou more hardware?
Router#sh run
Building configuration...
ip dhcp excluded-address 192.168.2.1 192.168.2.2
ip dhcp pool STU
 network 192.168.2.0 255.255.255.0
 default-router 192.168.2.1
 dns-server 198.153.192.50 198.153.194.50
 lease 0 2
ip dhcp pool ADMIN
 network 192.168.8.0 255.255.255.0
 default-router 192.168.8.1
 dns-server 8.8.8.8 1.1.1.1
interface FastEthernet0
 description CONNECTED TO WAN
 switchport access vlan 100
 no ip address
 spanning-tree portfast
 service-policy output p2p-drop
interface FastEthernet1
 switchport access vlan 200
 no ip address
interface FastEthernet2
 switchport access vlan 300
 no ip address
interface FastEthernet3
 switchport trunk native vlan 100
 switchport mode trunk
 no ip address
interface Vlan100
 description WAN
 ip nat outside
 ip virtual-reassembly in
interface Vlan200
 description LAN
 ip address 192.168.2.1 255.255.255.0
 ip nat inside
interface Vlan300
 description LAN_ADMIN
 ip address 192.168.8.1 255.255.255.0
 ip nat inside
ip default-gateway 192.168.1.254
ip nat inside source list 100 interface Vlan100 overload
ip route 0.0.0.0 0.0.0.0 192.168.1.254
access-list 100 permit ip 192.168.2.0 0.0.0.255 any
access-list 100 permit ip 192.168.8.0 0.0.0.255 any
end
Router#
21 Replies 21
yes exactly.
Good luck
KB
Yes Exactly
Good luck
KB
it should be as earlier.
interface Vlan200
description LAN
ip access-group 100 in
ip nat inside
interface Vlan300
ip access-group 101 in
ip nat inside
ip nat inside source list 102 interface Vlan100 overload
access-list 100 deny ip 192.168.2.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 101 permit ip 192.168.8.0 0.0.0.255 any
access-list 102 permit ip any any
Good luck
KB
with this Vlan 200 cant connect to internet
interface Vlan200
description LAN
ip access-group 101 out
ip nat inside
interface Vlan300
ip nat inside
ip forward-protocol nd
no ip http server
no ip http secure-server
access-list 101 deny   ip 192.168.2.0 0.0.0.255 192.168.8.0 0.0.0.255
access-list 101 permit ip 192.168.2.0 0.0.0.255 any
whenever I block access from one vlan to another, one of them do not have web access!!!!
compare below commands with your actual command. interfaces need to apply ALCs correctly. also the NAT ACL.
interface Vlan200
description LAN
ip nat inside
interface Vlan300
ip nat inside
Good luck
KB
And ACLs, needs to be like below.
Good luck
KB
