Site-to-Site Between 5512 and 5516 Problems!
machine23
Hi All ,
         I have an issue with the  site to site between 5512 and 5516
The site to site used to work .. but suddenly after a power outtage ...at the 5516 end the issue started .. we restarted all the fw accorss the sites .. not the 5516 will Tx but wont Rx from the 5512 .. Have tried to recreate the site 2 site from scratch  but no joy... I will update on the ASA Version
Francesco Molino
Can you give me details please? Phase 1 is completed or not?
5516 has only tx but what about 5512? Does it have tx and rx?
Are the public IPs static or dynamic?
What is your configuration on both ends?
Francesco
PS: Please don't forget to rate and select as validated answer if this answered your question
johnlloyd_13
Level 9
Level 9
hi,
could you post both the crypto IKE phase 1 and 2 policies from both ASA (mask sensitive info/IPs)?
also post a show crypto isakmp sa output from both ASA as well.
