small lab scale licensing for AnyConnect RA VPN
maurice.audet1
I am using a small-scale learning/test home and lab to learn/practice in support of my "paid (contract) work" for Government of Canada clients.  I already purchased and licensed a FPR-1010 Secure Firewall and  Catalyst-1000 Access switch, with associated support subscriptions.
I am trying to I am trying to build a test topology that will include 1 x Remote Access VPN (AnyConnect/Secure Mobility Client on both Linux and Windows clients featuring IKEv2/IPsec with strong encryption and certificate authentication).
My Cisco partner/vendor is consulting with Cisco about options, but as most in this community will know, the smallest package for Cisco AnyConnect is the "Advantage" license / support package, and there is a minimum order of 25 concurrent connections to a single headend.  In my case, the headend will be the FPR-1010 running ASA 9.23 software.  are there other options?
Marvin Rhoads
You have to purchase the minimum number of licenses (25 as you noted). Partners can request a customer lab licenses but it's only good for 30 days.
Note if you intend to test SAML and/or Suite B strong encryption you will need Apex licenses. Advantage (formerly known as Plus) and Premier (formerly known as Apex) are the current primary licenses types. The SKUs still reflect the old names.
The list price (in US$) for qty 25 each of the licenses are:
L-AC-PLS-LIC= $161.25
L-AC-APX-LIC= $387.25
So you can probably get the Advantage licenses for around US$100 or less after discounts.
