Network Security
“Join
Labels
I've recently converted an IOS CBAC (ip inspect) configuration to ZBFW.  By default all the inspection is just stateful at the L4 layer with the standard 'class-map type inspect <NAME>'.  However, it supports L7 inspection for some protocolsrouter(co...
Hi,I have received a CVE alert for my WS-C3850-12S switch when scanning it with Cisco Catalyst Center.The switch is currently running the following software version:Model: WS-C3850-12SSoftware Version: 16.3.5Software Image: CAT3K_CAA-UNIVERSALK9 INST...
I'm upgrading a HA pair of FPR-2130's running standard ASA software from version 9.20.4.235 to 9.20.4.50I upgraded the first unit in the pair and failed over to make this upgraded unit active, and now I need to do the other unit. The primary active u...
martin-d by • Frequent Visitor
  • 104 Views
  • 2 replies
Hello Cisco Community.I am facing a strange scenario whereby the cisco FMC unregisters FTDs. The FTDs affected are two new firepower 1100 and 1220 devices, when i register the device the FTD shows that it has been registered but on the FMC the regist...
derreck by • Frequent Visitor
  • 170 Views
  • 1 replies
Hi everyone!I've always enjoyed experimenting with automation and finding ways to make my everyday engineering work easier and more efficient.Throughout my career as a Network and Security Consultant, I've been involved in various enterprise infrastr...
nowy by • Visitor
  • 227 Views
  • 0 replies
  • 3 Helpful votes
Hello,I have a question to experts here. I found that FMC is supporting EFI environment, but a new deploy is needed. I'd like to deploy FMCv 10.0 (I tried 10.1 also) on ESXi 8.0u3 on my lab, but the VM is deployed everytime in BIOS mode from the offi...
project-jer by • Community Member
  • 204 Views
  • 0 replies
I'm unable to download the new Firepower Management Center virtual upgrade software. (No entitlement) I was able to download all prior to my license expiring. I went with a new vendor and now I'm only able to download the FTD software but not for the...
djohns777 by • Frequent Visitor
  • 283 Views
  • 2 replies
Hi guys, I have been working on Cisco FMC lately, trying to learn as much as possible so I can prepare to take my SNCF test. While doing this, I noticed in the top right corner I could change the view from "Light, Dusk, and to NEW". I changed mine to...
