Speed/Duplex issue on Pix 515
stuart.jones
I have an issue establishing connectivity between my Pix and a directly connected (cross-over cable) host.
My Pix is set to 100/full, however if the host is set to 100/full, it doesnt establish connectivity, if set to auto it negotiates with the Pix and ends up being 100/half !
The NIC is apparently a HP, not sure if there any issues with Pix's and these NIC's or im missing something.
Stu
selvaraj_s
This will be an issue with the Hardware(NIC) at the desktop. Try changing the hardware(NIC) at desktop end.
scoclayton
Level 7
Level 7
I would tend to think this is probably an issue with the end-host NIC card. Part of the ethernet standard that if only one side is set to autonegotiate, then it should default to the factory default duplex setting - which should be half-duplex. (note: the speed can be sensed, but duplex must be negotiated). Any chance you can change out the NIC card on the end-host in question and try again? I am not aware of any issues relating to negotiation problems on the PIX NIC cards.
The following doc (while not pertaining to the PIX specifically) may provide some helpful information.
http://www.cisco.com/warp/customer/473/3.html
Scott
