Split networking using IOS ZBF
tahequivoice
Level 7
Level 7
Is it possible to split a 3925 in half where the inside network connects, so the router can do traffic shaping, and default route to a true ASA, then the outside of the ASA connect back to the router and out to the internet?   Thinking along the lines of Context based Firewalling where you have multiple different firewalls on one ASA, I want to do two routers in one.
Julio Carvajal
You could use VRF's.
For more information about Core and Security Networking follow my website at http://laguiadelnetworking.com
Any question contact me at [email protected]
Cheers,
Julio Carvajal Segura
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
That is my other consideration.  Havent done small scale MPLS in a while.
No MPLS, you will be using VRF-lite.
That would be the best fit for your requirements,
Remember to rate all of the helpful posts
Cheers,
Julio Carvajal
