Sqlnet Communication problem
olukayode.olabanji
Community Member
Hi Community,
I have a challenge getting 2 Oracle servers with each located in "internal" and "DMZ" network segments.
The oracle server on the internal network can communicate with the one on the DMZ but the one on the DMZ can NOT talk to the one on the internal network.
The customer wants the architecture to enable realtime data updates on the Oracle in DMZ.
My config is as follows: I need help.
ciscoasa# wr t
: Saved
ASA Version 8.4(3)
hostname ciscoasa
domain-name default.domain.invalid
enable password 8Ry2YjIyt7RRXU24 encrypted
passwd 2KFQnbNIdI.2KYOU encrypted
names
name 10.1.184.131 Proxy_Server
name 192.168.10.1 Internet_Router
name 10.1.184.122 Mail_Server
name 10.1.184.116 Mail_Server_2
name 10.1.184.121 Mail_Server_3
dns-guard
interface GigabitEthernet0/0
nameif Inside
security-level 100
ip address 10.1.184.1 255.255.248.0 standby 10.1.184.254
interface GigabitEthernet0/1
description LAN/STATE Failover Interface
interface GigabitEthernet0/2
nameif DMZ
security-level 50
ip address 192.168.30.1 255.255.255.0 standby 192.168.30.2
interface GigabitEthernet0/3
nameif Outside
security-level 0
ip address 192.168.10.2 255.255.255.0 standby 192.168.10.20
interface Management0/0
nameif management
security-level 100
management-only
boot system disk0:/asa843-k8.bin
ftp mode passive
clock timezone GMT 1
dns server-group DefaultDNS
object network Proxy_Server
host 10.1.184.131
object network Mail_Server
host 10.1.184.122
object network Internet_Router
host 192.168.10.1
description Created during name migration
object network Mail_Server_2
host 10.1.184.116
object network Mail_Server_3
host 10.1.184.121
object network WebServer1
host 192.168.30.3
object network InternalNetwork
subnet 10.1.184.0 255.55.248.0
object network DMZ-IdentityPool
range 192.168.30.30 192.168.30.254
object network WebServer2
host 192.168.30.4
object network obj-remote
subnet 192.168.0.0 255.255.255.0
object network obj-DMZ
subnet 192.16.30.0 255.255.255.0
object network DatabaseServer
host 10.1.184.134
object network AppServer
host 10.1.184.126
object network MailServer
host 10.1.184.116
access-list Inside_access_in extended permit ip object Proxy_Server any
access-list Inside_access_in extended permit ip host 10.1.184.190 any
access-list Inside_access_in extended permit ip host 10.1.184.83 any
access-list Inside_access_in extended permit icmp host 10.1.184.190 any
access-list Inside_access_in extended permit ip host 10.1.184.67 any inactive
access-list Inside_access_in extended permit ip host 10.1.184.83 object Internet_Router
access-list Inside_access_in extended permit ip host 10.1.184.190 object Internet_Router
access-list Inside_access_in extended permit udp any any
access-list Inside_access_in extended permit icmp any any
access-list Inside_access_in extended permit ip object Mail_Server any
access-list Inside_access_in extended permit tcp object Mail_Server any eq smtp
access-list Inside_access_in extended permit ip object Mail_Server_2 any
access-list Inside_access_in extended permit tcp object Mail_Server_2 any eq smtp
access-list Inside_access_in extended deny tcp any any eq smtp
access-list Inside_access_in extended permit icmp host 10.1.184.43 any
access-list Inside_access_in extended permit ip object Mail_Server_3 any
access-list Inside_access_in extended permit tcp object Mail_Server_3 any eq smtp
access-list Inside_access_in extended permit ip host 10.1.184.190 host 192.168.30.3
access-list Inside_access_in extended permit tcp object InternalNetwork host 192.168.30.3 eq www
access-list Inside_access_in extended permit ip host 10.1.184.137 host 10.1.184.133
access-list Inside_access_in extended permit ip host 10.1.184.62 host 10.1.184.133
access-list Inside_access_in extended permit ip host 10.1.184.117 any
access-list Inside_access_in extended permit ip host 10.1.184.117 object Internet_Router
access-list Inside_access_in extended permit ip host 10.1.184.129 any
access-list Inside_access_in extended permit ip host 10.1.184.129 object Internet_Router
access-list Inside_access_in extended permit ip host 10.1.184.150 host 10.1.184.133
access-list Inside_access_in extended permit ip host 10.1.184.150 any
access-list Inside_access_in extended permit ip host 10.1.184.190 host 192.168.30.4
access-list Inside_access_in extended permit tcp object InternalNetwork host 192.168.30.4 eq www
access-list Inside_access_in extended permit tcp host 10.1.184.134 host 192.168.30.4 eq sqlnet
access-list Outside_access_in extended permit udp any eq domain object Proxy_Server
access-list Outside_access_in extended permit icmp object Internet_Router any
access-list Outside_access_in extended permit icmp any host 10.1.184.190
access-list Outside_access_in extended permit icmp any host 10.1.184.83 inactive
access-list Outside_access_in extended permit tcp any object Proxy_Server eq https
access-list Outside_access_in extended permit tcp any object Proxy_Server eq www
access-list Outside_access_in extended permit tcp any object Mail_Server eq smtp inactive
access-list Outside_access_in extended permit tcp any object Mail_Server_2 eq pop3
access-list Outside_access_in extended permit udp any eq domain object Mail_Server_2
access-list Outside_access_in extended permit tcp any object Mail_Server eq imap4 inactive
access-list Outside_access_in extended permit icmp any object Mail_Server inactive
access-list Outside_access_in extended permit tcp any object Mail_Server_2 eq smtp
access-list Outside_access_in extended permit tcp any object Mail_Server_2 eq imap4
access-list Outside_access_in extended permit icmp any object Mail_Server_2
access-list Outside_access_in extended permit icmp any host 10.1.184.43
access-list Outside_access_in extended permit tcp any host 192.168.30.3 eq www
access-list Outside_access_in extended permit tcp any host 192.168.30.3 eq https
access-list Outside_access_in extended permit icmp any host 192.168.30.3
access-list Outside_access_in extended permit icmp any any echo-reply
access-list Outside_access_in extended permit icmp any host 192.168.30.3 echo
access-list Outside_access_in extended permit tcp any host 192.168.30.4 eq www
access-list Outside_access_in extended permit tcp any host 192.168.30.4 eq https
access-list Outside_access_in extended permit icmp any host 192.168.30.4 echo
access-list branchgroup-SplitACL standard permit 10.0.0.0 255.0.0.0
access-list branchgroup-SplitACL standard permit 192.168.30.0 255.255.255.0
access-list DMZ_access_in extended permit tcp host 192.168.30.4 host 192.168.30.116 eq smtp
access-list DMZ_access_in extended permit icmp host 192.168.30.4 any
access-list DMZ_access_in extended permit ip host 192.168.30.4 host 192.168.30.134
access-list DMZ_access_in extended permit tcp host 192.168.30.4 host 192.168.30.134 eq sqlnet
pager lines 24
logging enable
logging timestamp
logging standby
logging emblem
logging list InformationalLog level informational
logging list InformationalLog message 101001
logging buffer-size 16384
logging console notifications
logging monitor errors
logging buffered critical
logging trap errors
logging asdm critical
logging mail informational
logging host Inside 10.1.184.132
logging host Inside 10.1.184.190 6/1470
logging debug-trace
logging ftp-server 10.1.184.190 \\marinasec\akanoa akanoa *****
logging permit-hostdown
logging class auth buffered emergencies trap emergencies
logging class bridge buffered emergencies trap emergencies
logging class config buffered alerts trap emergencies
logging class ip buffered emergencies trap alerts
logging class sys trap alerts
logging class ca trap emergencies
logging class email buffered emergencies trap errors
mtu Inside 1500
mtu DMZ 1500
mtu Outside 1500
mtu management 1500
ip local pool remoteusers 192.168.0.1-192.168.0.254
failover
failover lan unit secondary
failover lan interface stateful_failover GigabitEthernet0/1
failover replication http
failover link stateful_failover GigabitEthernet0/1
failover interface ip stateful_failover 192.168.20.1 255.255.255.252 standby 192.168.20.2
no monitor-interface management
icmp unreachable rate-limit 1 burst-size 1
icmp permit any Inside
asdm image disk0:/asdm-647.bin
no asdm history enable
arp timeout 14400
nat (DMZ,Outside) source static obj-DMZ obj-DMZ destination static obj-remote obj-remote
nat (Inside,Outside) source static InternalNetwork InternalNetwork destination static obj-remote obj-remote
nat (Inside,Outside) static Mail_Server no-proxy-arp route-lookup
nat (DMZ,Outside) static 192.168.30.3 dns
nat (DMZ,Outside) static 192.168.30.4 dns
nat (Inside,DMZ) static 192.168.30.134
nat (Inside,DMZ) static 192.168.30.126
nat (Inside,DMZ) static 192.168.30.116
access-group Inside_access_in in interface Inside
access-group DMZ_access_in in interface DMZ
access-group Outside_access_in in interface Outside
route Outside 0.0.0.0 0.0.0.0 Internet_Router 1
timeout xlate 3:00:00
timeout pat-xlate 0:00:30
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
timeout tcp-proxy-reassembly 0:01:00
timeout floating-conn 0:00:00
dynamic-access-policy-record DfltAccessPolicy
aaa-server vpn protocol radius
aaa-server vpn (Inside) host 10.1.184.119
key *****
aaa-server vpn (Inside) host 10.1.184.120
key *****
user-identity default-domain LOCAL
http server enable
http 10.1.184.190 255.255.255.255 Inside
http 10.1.184.2 255.255.255.255 Inside
http 10.1.184.83 255.255.255.255 Inside
http 192.168.1.0 255.255.255.0 management
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto ipsec ikev1 transform-set rmtset esp-3des esp-md5-hmac
crypto dynamic-map dyn1 1 set ikev1 transform-set rmtset
crypto dynamic-map dyn1 1 set reverse-route
crypto map mymap 1 ipsec-isakmp dynamic dyn1
crypto map mymap interface Outside
crypto ikev1 enable Outside
crypto ikev1 policy 1
authentication pre-share
encryption 3des
hash sha
group 2
lifetime 43200
telnet 10.1.184.83 255.255.255.255 Inside
telnet 10.1.184.190 255.255.255.255 Inside
telnet 10.1.184.167 255.255.255.255 Inside
telnet timeout 5
ssh 10.1.184.83 255.255.255.255 Inside
ssh 10.1.184.190 255.255.255.255 Inside
ssh 10.1.184.43 255.255.255.255 Inside
ssh timeout 5
console timeout 0
threat-detection basic-threat
threat-detection statistics
threat-detection statistics tcp-intercept rate-interval 30 burst-rate 400 average-rate 200
webvpn
group-policy branchgroup internal
group-policy branchgroup attributes
dns-server value 10.1.184.120
split-tunnel-policy tunnelspecified
split-tunnel-network-list value branchgroup-SplitACL
default-domain value marinasecuritieslimited.com
username sannib password 3gB/xWLMBVp/AjjW encrypted
username adebimpel password O./lZ/3rlYD/87u2 encrypted
username ojoawob password w1h9Aq2Welzv1fuW encrypted
username agbajer password NuDaZPLHC0BcF7iI encrypted
username oyenihib password eoxptVEUfczen6VR encrypted
username odewolef password yB12L9t1gcr.Wgx/ encrypted
username mainuser password 8KBTvbq5FOuoFce2 encrypted privilege 15
username maakano password c1Cb3uSluyfsyWUb encrypted
tunnel-group branchgroup type remote-access
tunnel-group branchgroup general-attributes
address-pool remoteusers
default-group-policy branchgroup
tunnel-group branchgroup ipsec-attributes
ikev1 pre-shared-key *****
class-map inspection_default
match default-inspection-traffic
policy-map type inspect dns migrated_dns_map_1
parameters
  message-length maximum client auto
  message-length maximum 512
policy-map global_policy
class inspection_default
  inspect ftp
  inspect h323 h225
  inspect h323 ras
  inspect rsh
  inspect rtsp
  inspect esmtp
  inspect skinny
  inspect sunrpc
  inspect xdmcp
  inspect sip
  inspect netbios
  inspect tftp
  inspect ip-options
class class-default
  user-statistics accounting
service-policy global_policy global
prompt hostname context
no call-home reporting anonymous
call-home
profile CiscoTAC-1
  no active
  destination address http https://tools.cisco.com/its/service/oddce/services/DDCEService
  destination address email [email protected]
  destination transport-method http
  subscribe-to-alert-group diagnostic
  subscribe-to-alert-group environment
  subscribe-to-alert-group inventory periodic monthly
  subscribe-to-alert-group configuration periodic monthly
  subscribe-to-alert-group telemetry periodic daily
hpm topN enable
Cryptochecksum:bbe838eb9af33fc84083989823bc0c22
: end
[OK]
ciscoasa#
Jouni Forss
Seems to me that you have configured Static NAT from "inside" to "dmz" so that the "inside" servers are visible to the "dmz" with the IP address belonging to the "dmz"
Is this something that you absolutely need? Is there something preventing you from using the IP address ranges on both "inside" and "dmz" and not doing NAT for them at all between those interfaces?
IF you want to keep the current setup intact regarding NAT, change the DMZ ACL to use the actual 10.1.184.x IP addresses as the destination IP address in the ACL.
In other words, always use the Real IP address of the host in the ACL configuration, NOT the NAT IP address. After doing that change I suppose it should also work for "dmz" to "inside". (NAT IP was used in the ACL in the ASA versions 8.2 and below, the Real IP address is used in software 8.3 and above)
Change
To
access-list DMZ_access_in extended permit tcp host 192.168.30.4 host 10.1.184.116 eq smtp
access-list DMZ_access_in extended permit ip host 192.168.30.4 host 10.1.184.134
access-list DMZ_access_in extended permit tcp host 192.168.30.4 host 10.1.184.134 eq sqlnet
You can also use the "object" names in the ACL.
Which would be
access-list DMZ_access_in extended permit tcp host 192.168.30.4 object MailServer eq smtp
access-list DMZ_access_in extended permit ip host 192.168.30.4 object DatabaseServer
access-list DMZ_access_in extended permit tcp host 192.168.30.4 object DatabaseServer eq sqlnet
Hope the above helps Please ask more if needed.
- Jouni
