SSH port forward won't work - ASA 5505 on ASA 8.4(1), ASDM 7.1(6)
joshua222
I'm trying to expose my sftp server (which is behind the asa unit) via ssh to an external ip in my ip block. So far it's just not working.
The pertinent bits of my running config are below. Does anyone see anything wrong with this?
object network sftp-internal
 host 192.168.2.155
object network sftp-external
 host xxx.xxx.xxx.138
 nat (inside,outside) static sftp-external service tcp ssh ssh
access-list outside_access_in extended permit tcp any eq ssh object sftp-internal eq ssh
Jon Marshall
Your acl is wrong because the source port won't be the same as the destination port ie. the entry should be -
access-list outside_access_in extended permit tcp any object sftp-internal eq ssh
Jon
