SSH problem connection
wkamil123
Level 4
Level 4
I have problem with a connection to ASA 5510 through SSH.
SSH works when the ASA is reload and works for some time and then the connection on terminal is blocked (TeraTerm).
The connection to ASA works by telnet and ASDM.
Below parts of configuration from ASA.
ssh 0.0.0.0 0.0.0.0 inside
ssh timeout 5
ssh version 2
aaa authentication telnet console LOCAL
aaa authentication enable console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 0.0.0.0 0.0.0.0 inside
Kamil
Can you please remove the ssh command and type it again i.e :
no ssh 0.0.0.0 0.0.0.0 inside
Also telnet into the device and issue the command show asp table socket and keep monitoring until all the entries with :22 get removed after sometime and then try to ssh into the device.
Let me know how it goes
Rahul
6 Replies 6
rmavila
Hi Kamil,
Can you tell what version of ASA are you running. Also can you tell me how long does the connection stay. Also send me the output of " show asp table socket"
Rahul
The ASA version is 8.2.3
Protocol  Socket    Local Address               Foreign Address         State
SSL       0000c41f  192.168.9.253:443           0.0.0.0:*               LISTEN
SSL       0001500f  91.216.5.200:443            0.0.0.0:*               LISTEN
TCP       0004345f  192.168.9.253:22            0.0.0.0:*               LISTEN
TCP       000548cf  91.216.5.200:22             0.0.0.0:*               LISTEN
TCP       015f93ef  192.168.9.253:23            0.0.0.0:*               LISTEN
TCP       01753dc8  192.168.9.253:23            192.168.100.91:49428    ESTAB
TCP       0176e7b8  192.168.9.253:22            192.168.251.69:37771    CLOSEWAIT
TCP       0177ee68  192.168.9.253:22            192.168.251.69:43188    CLOSEWAIT
SSL       017e1d38  192.168.9.253:443           192.168.100.134:26005   ESTAB
SSL       017f0ca8  192.168.9.253:443           192.168.100.134:26007   ESTAB
Rahul
Thank's for your replay, it's works now.
We have installed CACTI inside and configured to monitor ASA on 22 port and always status connection was CLOSEWAIT.
The sh ssh sessions do not show any open sessions.
Kamil
Enable "debug ssh 255" on the ASA (when on a Telnet session) and enable "terminal monitor" and then try an SSH and send the debugs.
Also, apply captures on the ASA and let me know how they look.
https://supportforums.cisco.com/docs/DOC-1222
Prapanch
Thanks for help.
I used deb ssh 255 but do not any logs on terminal when I try connect to ASA.
Kamil
