SSL Rule for site does not work
I have a site techsee.me and I do not want to decrypt it.
I created an SSL rule and I put the CN
The thing is that the rule shows the triangle with the exclamation mark and says the following:
"Because this rule depends on server certificate or negotiated session information, SSL inspection ability for traffic matching subsequent rules could be affected."
And off course the traffic does not match this rule.
I tried making the rule more specific by adding the port 443 but nothing changes.
Do you have any hint?
Thanks and regards,
Konstantinos
I believe you need to have the CN=*.techsee.me in the Subject DN section.  Try moving it there, let me know how it goes.
Please remember to select a correct answer and rate helpful posts
