Static NAT problem!!!
Leo_Stobbe
Level 3
Level 3
I was using ASA5510/asa712-k8.bin. But i had problem with http inspect command.It didn't work properly.And also having
enabled OSPF on ASA cpu usage became 35%.
After downloading Asa721-24-k8.bin...Http
inspect and CPU load problems has been solved. But i got new problem. Static NAT
stopped to work.
static (dmz,outside) tcp GLOBAL_IP smtp Private_IP smtp netmask 255.255.255.255
It worked with previous image.
Has anybody got any idea about that?
froggy3132000
Level 6
Level 6
Try changing to the following
static (dmz,outside) tcp interface smtp smtp netmask 255.255.255.255
Ok. Understood. Questions:
1.But if the Global IP isn't interface IP of ASA?
2. This is the bug of asa 7.2(1) ?
