steps for using fmc self generated certificate for SSL decryption
baselzind
Level 6
Level 6
can anyone tell me the summarized steps on how to self generate a CA and self sign a certificate to use in ssl decryption rules?
Dinesh Moudgil
This should be useful:
https://www.cisco.com/c/en/us/support/docs/security/firesight-management-center/200202-Configuration-of-an-SSL-Inspection-Polic.html#anc5
Dinesh Moudgil
P.S. Please rate helpful posts.
Cisco Network Security Channel - https://www.youtube.com/c/CiscoNetSec/
so i just generate FMC as a root Certificate Authority (CA) then i can use it in the ssl rule? and upload it to all user pc? or there is more steps involved?
While one CAN follow the steps outlined in the article @Dinesh Moudgil shared, it is not generally recommended to follow that approach. Decrypting all outbound traffic will severely constrain the throughput of a Firepower device (on the order of 80-90%).
Also, many sites and applications employ techniques (HSTS, certificate pinning etc.) to be resistant to such "man-in-the-middle" decryption, even from a client-trusted CA.
A better approach is to use decryption policies only for incoming traffic to organization-owned servers for which you have the server's private key.
Protect against malicious secure sites with a combination of Cisco Umbrella and AMP for Endpoints, in addition to the basic URL- and IP-based Security Intelligence blacklisting capabilities in Firepower.
Marvin Rhoads
Also, if you want to see a walk through of setting up FMC as a subordinate CA and implementing an SSL Policy, have a look at this Youtube video:
https://www.youtube.com/watch?v=6-egmsc8Egg
(Friday Firepower Hour - SSL Policy)
