Syn Timeout Issue.
stephen.stack
Level 9
Level 9
Hi Guys,
I'm hoping someone can help here.
I am getting these syn timeout issue on my asa 5510.
Jul 21 2008 16:19:04: %ASA-6-302013: Built outbound TCP connection 2576744 for outside:plug-2/25 (plug-2/25) to internal-vlan-20:coa-dun-db1/40643 (coa-dun-db1/40643)
Jul 21 2008 16:19:34: %ASA-6-302014: Teardown TCP connection 2576744 for outside:plug-2/25 to internal-vlan-20:coa-dun-db1/40643 duration 0:00:30 bytes 0 SYN Timeout
the following nat statements apply:
nat (internal-vlan-20) 1 access-list nat outside
access-list nat extended permit tcp object-group coa-dun-db object-group plug eq 123
access-list nat extended permit udp object-group coa-dun-db object-group plug eq ntp
access-list nat extended permit tcp object-group coa-dun-db object-group plug eq smtp
access-list nat extended permit ip any host x.x.64.133
access-list nat extended permit ip any host x.x.65.133
access-list nat extended permit tcp object-group coa-dun-back-net host sol-sco-hobbit1-ext eq 1984
access-list nat extended permit tcp object-group coa-dun-web-back host sol-sco-hobbit1-ext eq 123
access-list nat extended permit udp object-group coa-dun-web-back host sol-sco-hobbit1-ext eq ntp
access-list nat extended permit tcp host coa-dun-mon3-back any range www https
access-list nat extended permit udp host coa-dun-mon3-back host plug-1 eq domain
access-list nat extended permit udp host coa-dun-mon3-back host plug-2 eq domain
access-list nat extended permit tcp host coa-dun-mon3-back host plug-1 eq domain
access-list nat extended permit tcp host coa-dun-mon3-back host plug-2 eq domain
access-list nat extended permit ip x.x.93.32 255.255.255.248 host asa-ext
access-list nat extended permit ip x.x.86.72 255.255.255.248 host asa-ext
access-list nat extended permit icmp any any
Why are my connecitons not getting there.
Please help
Stephen
========================== http://www.rconfig.com A free, open source network device configuration management tool, customizable to your needs! - Always vote on an answer if you found it helpful
15 Replies 15
"Would you beleive that by upgrading the ASAs from 7.0 to 8.0 the bandwidth increased to over 40Mbps"
Interesting. Glad to hear that your issue is resolved.
You are welcome 🙂
