Talos Connectivity Problem
Ditter
Level 8
Level 8
Hi to all ,
i am getting many messages as the following:
Severity: critical
Module: Talos Communication
Description: 3 modules failed:
  • * URLDB- Failed to retrieve beaker inventory
  • * LSP- Failed to retrieve beaker inventory
My subscription is active (it expires in 2026).
Any ideas about why is this happening?   Is it a problem that has to do with Talos?
Please note that this is the first time i get this message.
The only change i did some days ago was to change the "Cached URLs Expire" which was set to never and i changed it to "week" but i do not think that my issue has something to do with it.
Any ideas,
Ditter.
94 Replies 94
s_SiD_s
Level 6
Level 6
Thanks to Cisco, they heard our prayers... 🙂
Today I saw that error has been gone
And cert now for the 1 year!!! hoooooray!
        Validity
            Not Before: Sep 29 13:41:36 2026 GMT
            Not After : Sep 28 13:41:36 2027 GMT
        Subject: CN = ce3419ea-b3cb-11f0-bcd3-5747d84a1b5c, O = Firepower Organization
primexm_networks
Frequent Visitor
Frequent Visitor
Same alert appeared when we upgraded our FMC to 7.6.6.
We've tried several commands to renew and restart Talos - to no aveil.
Alert cleared the next day. So I guess it might need time for the latest update/deployment of LSPs.
atsukane
Level 7
Level 7
Ditto, the cert was renewed over night and the health monitor is now all green 🙂 Not sure what process has renewed the cert though
Issuer: C = US, ST = California, L = San Jose, O = Cisco Systems Inc., OU = Security, CN = Keymaster CA 2
Validity
Not Before: Sep 29 23:50:30 2026 GMT
Not After : Sep 28 23:50:30 2027 GMT
Subject: CN = 4aa6e886-b95d-11eb-9eb0-25cdd78e49b5, O = Firepower Organization
pbe
Community Member
Have you enabled the Cisco Security Cloud or registered the FMC with Cisco Smart Software Manager for licensing, or was the certificate renewed even without these integrations?
Thanks in advance
No, Cisco Security Cloud integration isn't enabled, but I did enable the "Enable Cisco Success Network" option. This was suggested in Troubleshoot Talos Connectivity Status - Cisco
