Talos Connectivity Problem
Ditter
Level 8
Level 8
Hi to all ,
i am getting many messages as the following:
Severity: critical
Module: Talos Communication
Description: 3 modules failed:
  • * URLDB- Failed to retrieve beaker inventory
  • * LSP- Failed to retrieve beaker inventory
My subscription is active (it expires in 2026).
Any ideas about why is this happening?   Is it a problem that has to do with Talos?
Please note that this is the first time i get this message.
The only change i did some days ago was to change the "Cached URLs Expire" which was set to never and i changed it to "week" but i do not think that my issue has something to do with it.
Any ideas,
Ditter.
65 Replies 65
s_SiD_s
Level 5
Level 5
Good day!
fresh install 7.6 and upgraded to Version 7.6.2.1 (build 3) and FMC and FTDv
same error happens LSP-Failed to retrieve beaker inventory
pmtool restartbyid talosAgent
pmtool restartbyid beaker3
make warning go away...
i've chcked cert.
Validity
Not Before: Jan 30 22:32:39 2024 GMT
Not After : Mar 30 22:32:39 2025 GMT
it is odd that it is still happens)
jwornstaff
Level 3
Level 3
Still receiving the critical LSP alerts in 7.7.11. Restarting beaker3 process clears the alert for about 12 hours and returns....so ignoring. I have personnel monitoring the health status and get called everyday. I tried multiple images from 7.4 to 7.6 to 7.7 and same thing. Along with all the work arounds and just comes back.
You need to check the certificate under “openssl x509 -text -in /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem”.
Once it has expired, the error message appears. However, I have not yet been able to determine why the FMC cannot obtain a new certificate. All configuration adjustments on Cisco's part were unsuccessful. During the last update from 7.7.10 to 7.7.11, I received a new certificate that is valid until August 2026. I hope that it will always be updated automatically in future updates.
s_SiD_s
Level 5
Level 5
I have caught an alarm today, that never seen before)
FMC 7.6.5-106
FTDv-HA 7.6.4-69
Talos Connectivity Status Apr 15, 2026 11:10 AM 1 modules failed: * Enrichment- failed to perform batch query: rpc error: code = Internal desc = Internal error occurred: Request failure: connection error: timed out
root@fmc:/var/sf/beaker3# openssl x509 -text -in securefirewall-dev-prod-01_prod.pem
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 95913372 (0x5b7859c)
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, ST = California, L = San Jose, O = Cisco Systems Inc., OU = Security, CN = Keymaster CA 2
Validity
Not Before: Aug 27 15:51:59 2025 GMT
Not After : Aug 31 15:51:59 2026 GMT
Subject: CN = securefirewall-cdfmc-eng-prod-02, C = US, ST = California, L = San Jose, O = Cisco, OU = Security
Subject Public Key Info:
So, I restarted
root@fmc:/var/sf/beaker3# pmtool restartbyid talosAgent
root@fmc:/var/sf/beaker3# pmtool restartbyid beaker3
error gone.
  - @s_SiD_s        Have a look at : https://bst.cisco.com/bugsearch/bug/CSCwq37578?rfs=qvred
                            I think the bug report is not exactly aligned with your issue but it also contains
                                     'failed to perform batch query' ;
                           which may give you insights , possible reason for ,  ... concerning your  topic
  M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
i do not have cloud services enabled.
this is first time error is seen.
will keep an eye on it)
