Talos Connectivity Problem
Ditter
Level 8
Level 8
Hi to all ,
i am getting many messages as the following:
Severity: critical
Module: Talos Communication
Description: 3 modules failed:
  • * URLDB- Failed to retrieve beaker inventory
  • * LSP- Failed to retrieve beaker inventory
My subscription is active (it expires in 2026).
Any ideas about why is this happening?   Is it a problem that has to do with Talos?
Please note that this is the first time i get this message.
The only change i did some days ago was to change the "Cached URLs Expire" which was set to never and i changed it to "week" but i do not think that my issue has something to do with it.
Any ideas,
Ditter.
2 Accepted Solutions
Correct - when I reached out to TAC this is what I was told
CSCwo63951 - FMC Client side certificate used to communicate to Talos did not auto-renew correctlyThe Beaker3 process on the FMC is supposed to auto-update the client side certificate it is using to authenticate to Talos for downloads. This process is not auto-updating the certificate without being reloaded. You can workaround this issue by performing a manual reload of the
Beaker3(talos_agent) process with the following commands:
> expert$ sudo su -
pmtool restartbyid talosAgent
# pmtool restartbyid beaker3
Please note this may
take 10-15 minutes to resolve the health alarms that you receive. Additionally, please note that this workaround will request a new certificate that will expires in 5 days. You will need to re-perform this workaround every
5 days. Cisco will be releasing VDB 406 shortly that will renew this certificate for 1 year. Once this VDB has been released and installed on your FMC you will no longer need to perform the workaround every 5 days
Running this "start_beaker_process.sh beaker3" resolved my issue.
The certificate "openssl x509 -text -in /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem" is now in date and I am able to get URL Filtering updates under the Cloud Integrations section. I am running FMC 7.7.
94 Replies 94
Several others in the community have reported this as well.  It appears to be a Talos problem at this time.
Marvin Rhoads
It's a problem on the TALOS side. Cisco have been notified and are looking into it.
Snort rule and URL database updates may be affected. It should not affect any traffic forwarding.
HQuest
Level 5
Level 5
root@fmc:/var/sf/beaker3# grep client_cert /etc/sf/beaker3/beaker3.cfg.template
client_cert = /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem
root@fmc:/var/sf/beaker3# openssl x509 -text -in securefirewall-dev-prod-01_prod.pem
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 46240369 (0x2c19271)
Signature Algorithm: sha256WithRSAEncryption
Issuer: C = US, ST = California, L = San Jose, O = Cisco Systems Inc., OU = Security, CN = Keymaster CA 2
Validity
Not Before: Jan 30 22:32:39 2024 GMT
Not After : Mar 30 22:32:39 2025 GMT
Subject: CN = SFW76EVAL-prod-01, C = US, ST = California, L = San Jose, O = Cisco, OU = Security
Not really on Talos end but a screw up from Cisco. A locally deployed certificate expired yesterday and hasn't been renewed everywhere. Whoops.
My contact at Cisco advised:
"Yes. We are going to push an update to fix it. No user interaction. Need one more day"
BACANEL
Level 2
Level 2
Following this case as I have the same problem.
erdyer
This is a known issue and should be fixed soon.  In the meantime you can contact TAC for a temporary workaround.
Thank you, I have checked this morning and Cisco has not fixed it yet. I will reached out to TAC.
If the error is bothering you, you can fix it manually with the following commands from your FMC cli expert mode, root user (sudo su -):
expert
sudo su -
<enter password when prompted>
pmtool restartbyid fireamp
pmtool restartbyid CloudAgent
Thanks Marvin, that is helpful.
I'm wondering, though, if this is sustainable and/or long term. The expired beaker3 certificate has been refreshed but with a short 4 days/96-hours lifetime. Is this workaround truly to give Cisco just enough time to push a long term fix?
root@fmc:~# openssl x509 -text -in /var/sf/beaker3/securefirewall-dev-prod-01_prod.pem
Certificate:
Data:
Version: 3 (0x2)
Serial Number: 81794058 (0x4e0140a)
Validity
Not Before: Apr 2 14:49:33 2025 GMT
Not After : Apr 6 14:49:33 2025 GMT
Subject: CN = a5898858-a7fd-11ee-94a3-3c06584886f3, O = Firepower Organization
I've been told those are short-term-by-design client side certificates. The fix will make it so that they are auto-renewed based on instructions in the payload received from Cisco (as had been working previously).
Update: BugID is published here https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwo63951
> expert$ sudo su -
Is there an ETA when VDB 406 will be released.
It was released on Monday 7 April 2025.
Hello is this issue still present, i have upgraded FMC to 7.6 recommended and getting the same errors as explained here, I am running VDB version 414.
thanks
