Tracing Connection in Multi context ASA
mahesh18
Level 6
Level 6
Hi Everyone,
Trying to trace the path going via the ASA  in Multi context Active active Mode.
Need to check the port connection between 2 servers
Server A is connected to switch 1
Server B is connected to Switch 3
Here is topology
Sw1    Sw2   ASA   Sw3
ASA  has two context  1 and 2  and 1 is admin.
Context 1 has few interfaces.
Interface X  of Context 1  has Server A  subnet there
Interface Y of context has Server B  subnet there.
In other words traffic going from server A  to server B  goes via interface  x and interface y of ASA.
Or we can say that interface x of ASA  has connection to Sw2 and interface y has connection to Sw3.
i try to run the packet tracer through the ASDM and CL  it failed.
I verify that ASA which i log on is Active for group 1 and context 1 is member of group 1
I used source interface as X  is this right interface to choose?
Mahesh
3 Accepted Solutions
Julio Carvajal
Hello Mahesh,
We are missing a little info
You did not specify the context, is it on the same context(I mean context 1 as well)
If that is the case then is just a regular connection across a firewall like it were on single mode,
Make sure you have the right Policies,NAT,ACL in place and u should be good,
Let us know if it's a different context
Remember to rate all of the helpful posts
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Mahesh,
Okey, I did not pay attention to the following
"I tested with existing ACL that allows traffic from source to destination server still packet tracer does not work
gives error Virtual firewall classification failed"
Is any of the interfaces in place being shared between multiple contexts ?
On the NAT statements you have, is there any being used with the keyword "any"
what is the exact version you are running?
Julio Carvajal
Traffic from switch 1 goes all the way to SW 3 SVI VLAN say 1 passing via ASA.
Then to reach the destination server B does it touch the ASA  or not?
It does not , traffic will reach the switch and it will get routed to the proper SVI, traffic will never reach the ASA.
As per my understanding it should not touch the ASA  as SW3 is layer 3 switch and both the source and destination subnets are connected to sw3?
That is correct, it will not flow to the ASA,
Julio Carvajal
Julio Carvajal
11 Replies 11
Julio Carvajal
Hello Mahesh,
Julio Carvajal
Hi Julio.
The interface Y is also in context 1
When i ran the packet tracer from CLI using source interface as X  it do not work
There is ACL that allows the traffic from Source to destination.
But packet tracer does not work
Mahesh
Hello Mahesh,
Can you share the interface allocation configuration, the show run of that context and the exact packet tracer config and output?
Julio Carvajal
Hi Julio,
As packet tracer is even not working for ACL  which is configured on the ASA and traffic for that is allowed that shows
some odd behaviour of packet tracer when ASA is configured with Multi context mode.
I fine some these urls  about packet tracer in multi context mode.
https://supportforums.cisco.com/thread/2117679
http://www.mail-archive.com/ccie_security@onlinestudylist.com/msg02474.html//www.mail-archive.com/ccie_security@onlinestudylist.com/msg02474.html
Mahesh
Hello Mahesh,
Julio Carvajal
Hi Julio,
interfaces 0/3 is shared but interfaces x and y are not shared.
IOS is 8.05(28)
Interface X has
nat(X) 0 0.0.0.0.0 0.0.0.0.
Mahesh
Okey but X and Y are not logical interfaces derived from ether 0/3 right?
Is there a way you can share the configuration and packet tracer you are doing
Julio Carvajal
Hi Julio,
After doing some more digging i fig out that Both source and destination are under same interface of ASA which is Y.
Interface X is not involved.
Here is update info
Sw3 has SVI VLAN for both the Servers.
Server A  which is connected to Switch 1  has SVI VLAN in SW3.
Server B which is connected to Switch  3 has SVI  VLAN  in SW3.
Both the SVI vlans in SW3  have different subnets.
Need to understand the traffic flow from server A  to server B
Need to confirm with you?
Mahesh
Julio Carvajal
Julio Carvajal
Hi Julio,
Many thanks again.
Its always good to have your confirmation.
Mahesh
Hello Mahesh,
My pleasure to help,
Julio Carvajal
