Traffic Flow between Transparent and Routed FW.
mahesh18
Level 6
Level 6
Hi Everyone,
Need to confirm here the traffic flow between 2 FW.
Say we have Core Switch 1  it is learning route to subnet 172.x.x.x  via interface x of Routed FW.
Routed FW learns Route to Destination subnet 172.x.x.x   via its  interface Y.
Now Interface Y connects to interface Y of Transparent FW.
Transparent FW has interface Z  which has destination subnet 172.x.x.x.
So in short we can say that if someone need to reach the Destination subnet 172..x.x.x  and its default gateway is core switch then traffic will follow the
above path to reach the subnet 172.x.x.x??
Mahesh
3 Accepted Solutions
Julio Carvajal
Hello Mahesh,
Well,
The Transparent Firewall cannot route so I would say that
The interface Y of the Router FW and both interfaces on the transparent firewall on the 172.16.x.x..
That would make sense but you cannot route to a subnet via a transparent firewall IP address.
The transparent firewall does not have a routing table to route traffic across itself.
Julio
Julio Carvajal
Senior Network Security and Core Specialist
CCIE #42930, 2xCCNP, JNCIP-SEC
Hello Mahesh,
If the FW Y interface and Transparent Firewall is on the 172.x subnet ( the destination you are trying to go you are going to be fine),
Is this the case?
Julio Carvajal
Hello
Exactly, the packet will be forward to the LAN, then the devices in between FW transparent and switches will send the traffic to the right ports,
Julio
Julio Carvajal
5 Replies 5
Julio Carvajal
Hello Mahesh,
Well,
Julio
Julio Carvajal
Hi julio,
you are correct as transparent FW is just layer 2 and both  interfaces Y and Z have same IP address.
So in order to  move packet from  interface Y to Z  transparent FW uses  arp table to get the mac of device connected to interface Z of transparent FW?
Mahesh
Hello Mahesh,
Is this the case?
Julio Carvajal
Hi Julio,
Yes Dest subnet and Y interface of Transparent FW  are on same subnet.
So FW just forward the packet to device by looking at mac address table right?
Mahesh
Hello
Julio
Julio Carvajal
