transport input ssh problem?
Iloveyou
Level 3
Level 3
I realized that when I use the transport input ssh command, I can only ssh in from outside the network but I cannot ssh from inside the network.
What can be the problem?
@Iloveyou the command transport input ssh will only permit SSH and deny telnet, it does not affect where you can SSH from. Do you have an ACL on the VTY line that restricts what networks you can SSH from? Please provide your configuration for review.
Marius Gunnerud
Please provide the full running configuration (remove any usernames and public IPs), also, what device is this and what software version is it running?
Please remember to select a correct answer and rate helpful posts
It is firewall blocking issue.
Thanks all.
