two outside interface for two inside VLAN network using one ASA Box
r.docuyanan
Level 3
Level 3
Is it possible to use the extra port of the ASA5510 with base license upgraded to enhanced license to for a new OUTSIDE segment network that will NAT to a new internal VLAN network, the 3rd interface of the ASA is running trunk.
Say 10.10.X.X(new internal VLAN) translates to the new OUTSIDE interface ( with network 192.11.X.X
Any links how to do this in ADSM? or commandline?
mlowery
Level 2
Level 2
Well, you can only have 1 *real* default gateway, so no, I don't think you can do that.
But if the traffic is always initiated from the outside and is stateful, (ie tcp), then you can do that by creating 2 default routes with different metrics and doing static NAT.
