Unable_to_Telnet_to_ASA_Management_interface_from_Outside
secureIT
Level 4
Level 4
Hi All,
Is that possible to telnet to ASA version 8.0.3, outside interface OR Management interface from OUTSIDE Network ?
I have configured the below
telnet x.x.x.x x.x.x.x management
interface managment 0/0
no management-only
But still unable to get access to the device.
Can anyone suggest me is this possible or not ??
regards
Rajesh P
You cannot telnet into the ASA box from Outside, except if you are coming via a IPSEC tunnel.
You will have to use SSH.
For SSH Access , follow below commands
hostname(config)# crypto key generate rsa modulus modulus_size
hostname(config)# ssh source_IP_address mask source_interface
hostname(config)# ssh timeout minutes
