URGENT: interface administrative weight for routing decisions
gbledsoe
I need to get routing updates between a pair of routers over two different interfaces and have the recieving router prefer one interface over the other - can use either EIGRP or RIP 2. Anybody know how to make that happen?
afakhan
Level 4
Level 4
not sure if I understand your Q, but if its abt load balancing across the vpn tunnel, then make sure that you are terminating your ipsec tunnel on a loopback interface on that same router.
thx
afaq
