Using inside interface IP address for PAT
bhogue
Hi all,
I have a direct connection to a remote vendor from my ASA 5516 (9.5(2)) for a hosted web based application.  I need to add an IP on my inside interface (192.168.2.26) to use for a PAT address to the vendor.  This is the path:
Client (192.168.1.0/24) -> Core switch (192.168.2.1/24) -> Firewall inside interface (192.168.2.25/24) -> Firewall vendor interface  (10.10.10.101/29) -> Vendor firewall(10.10.10.97/29) -> Web App (10.10.11.0/24)
This is what I've tried but it isn't working:
route inside 192.168.1.0 255.255.255.0 192.168.2.1 1
route vendor 10.10.11.0 255.255.255.0 10.10.10.101 1
object network VENDOR_LOCAL_PAT
 subnet 192.168.1.0 255.255.255.0
object network VENDOR_REMOTE_PAT
 subnet 10.10.11.0 255.255.255.0
object network VENDOR_PAT_IP
 host 192.168.2.26
nat (inside,vendor) source dynamic VENDOR_LOCAL_PAT VENDOR_PAT_IP destination static VENDOR_REMOTE_PAT VENDOR_REMOTE_PAT
Can someone tell me what I'm doing wrong?
Bill
Hi Bill,
the nat rule look ok, but I think that route to vendor is false. Can you try:
> route vendor 10.10.11.0 255.255.255.0 10.10.10.97 1
Best regards,
