VMS 2.2 installation problem 90 days
m.cucchi
Level 3
Level 3
Hello ,
i have tried to install vms 2.2 90 day evaluation from files dowloaded from CCO ( 1 zip and 3 other files ), but i have not found any explanations how to install and the product.
I have unzipped a files but during the unzip but appear a request to insert a cd1 without any possibility.
How i can install the product ?
any suggestion is appreciate
Massimo
jsivulka
Level 10
Level 10
Try this: Download all the 4 files into a single directory. Use PowerArchiver to extract the files (http://www.powerarchiver.com/). Check the file size by right-clicking on the file and ensure that it matches the file size mentioned on the download page. Using File Explorer, double-click the zip file and extract to the directory to which the files are originally copied. Go to the directory to which the files have been extracted and double-click 'Setup.exe'. Start by installing only Common Services. The other components can be installed later as required.
