vpn block wireless connection?
interfacedy
Hi Cisco anyconnect vpn is installed at PC. then the wireless cannot be connected until the vpn removed. Please see the below picture. The one next to red triangle is the original zip file and all of other are produced by this zip file.. Once clicking on file "Setup.exe" to run, the blue window appear where there are a lot choices. I chose the first six items to install.
My question is which one caused wireless disconnection? Second question is i just want to access app remotely without other needs. so which one do I need? Thank you
2 Accepted Solutions
ammahend
its the NAM (Network Access Manager) module. For most part for Remote VPN access just install Core & VPN as well as diagnostic and reporting for any troubleshooting.
If you install NAM, you have to use NAM module to connect to wireless you can not use native windows supplicant until you disable NAM.
-hope this helps-
Willjoe2442
How to Unblock a VPN
Switch server / IP address.
Change the VPN protocol or port.
Use obfuscation (stealth protocols)
Use SmartDNS.
Get a dedicated IP address.
Change DNS servers
Will
ammahend
-hope this helps-
Willjoe2442
Use SmartDNS.
Change DNS servers
Will
interfacedy
Thank you
