Web VPN user connection problem.- help please..
zaidumer
i have an ASA5520 ith Web VPN (SSL client based)setup.
when a user tries to connect using a web browser he get the login prompt and the user is authenticated as well however during that time it gets an error that the the ip forwarding table information could not be verified
im attaching the sys log entries . please if anyone can help it would be great.
thanks.
zaid.
didyap
Level 11
Level 11
This error may occur because of change in the client's routing table. Make sure that the addresses you are getting are not same or overlapping. Another reason could be the MTU size on the client side. Make sure that MTU size is same on both ends.
