Webvpn and anyconnect on same interface
srihari4cisco
Hello !!
Can we configure WebVPN and anyconnect on same interface ?
We have ASA 5520 running with code 9.1(2) with vpn plus license installed. Webvpn is already configured in it. users are already using it. We have a legacy VPN concentrator for RAVPN. Now the client want to move all the RAVPN users from VPN concentrator to ASA using anyconnect.
As we already have webvpn on the asa box, can we configure anyconnect on the same firewall on same interface. ? if so what are the parameters we need to consider.
I am attaching the sh ver of firewall . Any help in this regard is highly appreciated.
Cheers,
Octopus.
adamtodd16
Level 6
Level 6
The simple answer is yes. It's not problem at all.
fatalXerror
Level 7
Level 7
Hi Octo Vian,
Good Day!
Yes you can. Just a heads up, try to configure the AnyConnect profile via ASDM VPN Wizard if you're not familiar regarding the configs.
Niks.
johnlloyd_13
Level 11
Level 11
hi,
as others have mentioned, yes, you could configure it both.
i've used ASDM a lot of times when it comes to VPN config on the ASA.
see helpful link:
http://ccnpsecuritywannabe.blogspot.com/2014/06/anyconnect-secure-mobility-client.html
