wierd pix 501 problem
shane
I have a pix 501 running 6.2.2 with 3 computers plugged into it. I have 3 machines plugged into it.
Computer A is a unix box
Computer B is a win2k box
Computer C is a NT 4.0
Computer A can always ping the inside of the pix and the pix can always ping Computer A.
Computer B and C, when pinging the inside interface of the pix you may get one reply and then all timeouts. Now the weird thing is even though Computer B and C cannot ping the pix they CAN ping each other all the time.
I have tried switching ports on pix, cables, ... and still the same results.
Question: Is there a throughput limit or something on the 501 or perhaps a caveat that will shut down some ports from passing data.
Any Ideas will be appreciated.
b.speltz
Level 4
Level 4
This looks more like a configuration problem to me.
