WS-SVC-FWM-1-K9 Missing Running Activation Key HELP?
gary
Hi to All
How do I go about getting a  Running Activation Key ?
My WS-SVC-FWM-1-K9 is missing the  Running Activation Key, how do I go about obtaining a  Running Activation Key ?
STEVE
Hardware:   WS-SVC-FWM-1, 1024 MB RAM, CPU Pentium III 1000 MHz
Flash  2.20    TOSHIBA THNCF128MBA @ 0xc321, 20MB
0: gb-ethernet0: irq 5
1: gb-ethernet1: irq 7
2: ethernet0: irq 11
Licensed Features:
Failover:           Enabled
VPN-DES:            Enabled
VPN-3DES:           Enabled
Maximum Interfaces: 256
Cut-through Proxy:  Enabled
Guards:             Enabled
URL-filtering:      Enabled
Throughput:         Unlimited
ISAKMP peers:       Unlimited
Security Contexts:  2
This machine has an Unrestricted (UR) license.
Serial Number: SAD11010546
Running Activation Key: 0x00000000 0x00000000 0x00000000 0x00000000
Configuration last modified by enable_15 at 05:08:20 Feb 10 2011
FWSM#
Leo Laohoo
Mine is fine and has the same running activation key.   What is the result of the command "sh activation"?  I believe if you get the response of  "The Running Activation Key is not set, using default settings:" or "The flash activation key is the SAME as the running key." then it should be fine.
I will try this out and see what happens
mirober2
Hi Gary,
Just to clarify, the all 0s key is the default activation key for the FWSM. This just means that you have the base feature set and is perfectly normal if you didn't purchase a license for additional security contexts.
If you did purchase a license, you should have a received a PAK number. You would need to enter this PAK into www.cisco.com/go/license along with your FWSM's serial number. This will generate an activation key that can be entered into the FWSM.
Hope that helps.
-Mike
gary
Problem has been sorted out.   Email Cisco licensing@cisco.com and got the  Activation Key within 5 mins
