alzverev
I'm currently working on sample NeXt applications for the participants of HackZurich. The apps are open-source and are located on GitHub.
I'd be glad to get a feedback and any suggestions regarding NeXt apps. Create 'an issue' if you have noticed something or have an idea.
You can find the code in the repository:
CiscoDevNet/opendaylight-sample-apps · GitHub
There should also be some ODL snippets and stuff in a while. Look for 'next-*' subfolders.
Alex
