aeguiart
Tool available at: https://cway.cisco.com/tools/cat4k_cpu_pkt_to_pcap/
Catalyst 4500 CPU Packet Buffer Parser
   The Catalyst 4500 CPU Packet Buffer Parser tool converts the output of 'show platform cpu packet buffered' from a Catalyst 4500/4900 platform into a PCAP file and provides L2 and L3 statistics.
Description
The Catalyst 4500 CPU Packet Buffer Parser tool converts the output of 'show platform cpu packet buffered' from a Catalyst 4500/4900 platform running IOS or IOS-XE into a PCAP file (that can be analyzed with WireShark) and provides L2 and L3 statistics including:
   * Top Talkers
   * Detailed Counters per L2/L3 packet field
Cat4500 CPU Packet Buffer Parser Features:
   * Outputs including fields in both decimal (older IOS) and hex (IOS-XE) outputs.
   * Multiple cpu packet buffer captures in the same file
 * Supported frames and packets:
     IP, ARP, CDP, dot1q, STP BPDU and VSL frames.
Use Cases
The Cat4500 CPU Packet Buffer Parser is commonly used when troubleshooting any of the following issues on Catalyst 4500/4900 switches:
  • High CPU utilization, which could happen in Campus Networks due to various reasons including:
    • Spanning Tree instability due to misconfigured hosts, misbehaved hosts, L1 problems
    • Worm/Virus causing affecting stations to burst traffic to the network or DoS attacks
    • ARP or Broadcast storms.
    • Multicast streams.
  • Hosts not able to reach a destination upstream.
Tool Developers:
* Ryan Bolenbaugh - High Touch Engineer, FTS
* Alejandro Eguiarte - Technical Leader, Services
Guidelines:
When using the Catalyst 4500 CPU Packet Buffer Parser tool on CCO or at the development site you just need to drag & drop a text file containing the output of `show platform cpu packet buffered` and click Run.
Here is a sample output of the script:
Expanded statistics per frame/packet field:
Feedback
Your feedback is valuable to help us improve the tool. Please do not hesitate in adding a comment using the icon in the upper right corner of this page.
