05-06-2013 03:36 AM - edited 03-01-2019 04:55 PM
In this document we will see Comparision of basic Static route Configuartion between cisco IOS and IOS XR.
In this example we have R1 running Cisco IOS and PE1 IOS XR.
In IOS XR static route is configure under router subsection called "router static”. Static route can point to a next-hop interface, next-hop IP address, or both. In this example we have pointed to both next-hop IP address as well to interface.
R1PE1
R1#conf t Enter configuration commands, one per line. End with CNTL/Z. R1(config)# *May 6 16:12:52.187: %SYS-5-CONFIG_I: Configured from console by console R1(config)#ip route 1.1.1.1 255.255.255.255 fa0/0 10.1.1.1 R1(config)#do wr Building configuration... [OK] R1(config)# | RP/0/0/CPU0:PE1#conf t Mon May 6 10:42:14.853 UTC RP/0/0/CPU0:PE1(config)#router static RP/0/0/CPU0:PE1(config-static)#address-family ipv4 unicast RP/0/0/CPU0:PE1(config-static-afi)#1.1.1.1/32 gig0/0/0/1 10.1.1.1 RP/0/0/CPU0:PE1(config-static-afi)#commit Mon May 6 10:42:39.561 UTC RP/0/0/CPU0:PE1(config-static-afi)# |
You can also use floating route as well enable permant option to static route as shown below:
R1PE1
R1#conf t Enter configuration commands, one per line. End with CNTL/Z. R1(config)#ip route 1.1.1.1 255.255.255.255 fa0/0 10.1.1.1 permanent 200 R1(config)#end R1#wr Building configuration...
[OK] R1# | RP/0/0/CPU0:PE1#conf t Mon May 6 10:42:14.853 UTC RP/0/0/CPU0:PE1(config)#router static RP/0/0/CPU0:PE1(config-static)#address-family ipv4 unicast RP/0/0/CPU0:PE1(config-static-afi)#1.1.1.1/32 gig0/0/0/1 10.1.1.1 permanent 200 RP/0/0/CPU0:PE1(config-static-afi)#commit Mon May 6 10:42:39.561 UTC RP/0/0/CPU0:PE1(config-static-afi)# |
To configure IPv6 static route you just need to change address-family as show below:
IPv6 static route:
R1PE1
R1#conf t Enter configuration commands, one per line. End with CNTL/Z. R1(config)#ipv6 route 2001:1:1:1::/64 fa0/0 fe80::2 R1(config)#end R1#wr Building configuration... [OK] R1# | RP/0/0/CPU0:PE1#conf t Mon May 6 12:38:55.043 UTC RP/0/0/CPU0:PE1(config)#router static RP/0/0/CPU0:PE1(config-static)#address-family ipv6 unicast RP/0/0/CPU0:PE1(config-static-afi)#2001:1:1:1::/64 gig0/0/0/1 fe80::1 RP/0/0/CPU0:PE1(config-static-afi)#commit Mon May 6 12:39:31.311 UTC RP/0/0/CPU0:PE1(config-static-afi)# |
You can also specify Static route for VRF instance. The VRF can be the default VRF or a specified VRF. Specifying a VRF, using the vrf vrf-name command, allow you to enter VRF configuration mode for a specific VRF where you can configure a static route. If a VRF is not specified, a default VRF static route is configured.
R1
PE1
R1#conf t Enter configuration commands, one per line. End with CNTL/Z. R1(config)#ip route vrf Cust_A 1.1.1.1 255.255.255.255 10.1.1.2 R1(config)#do wr Building configuration... [OK] R1(config)#end R1# | RP/0/0/CPU0:PE1#conf t Sun May 5 16:22:45.272 UTC RP/0/0/CPU0:PE1(config)#router static vrf Cust_A RP/0/0/CPU0:PE1(config-static-vrf)#address-family ipv4 unicast RP/0/0/CPU0:PE1(config-static-vrf-afi)#1.1.1.1 255.255.255.255 10.1.1.2 RP/0/0/CPU0:PE1(config-static-vrf-afi)#commit Sun May 5 16:23:29.529 UTC RP/0/0/CPU0:PE1(config-static-vrf-afi)#end RP/0/0/CPU0:PE1# |
Verification:
You can verify your static route configuration there is only single command you can use to verify IPv4/IPv6 and specific VRF route as shown below.
R1
PE1
R1#sh ip route static
R1#sh ip route vrf Cust_A static
R1#sh ipv6 route static | P/0/0/CPU0:PE1#sh running-config router static Mon May 6 13:10:22.244 UTC router static address-family ipv4 unicast 1.1.1.1/32 10.1.1.2 1.1.1.1/32 GigabitEthernet0/0/0/1 10.1.1.1 200 permanent ! address-family ipv6 unicast 2001:1:1:1::/64 GigabitEthernet0/0/0/1 fe80::1 ! vrf Cust_A address-family ipv4 unicast 1.1.1.1/32 GigabitEthernet0/0/0/2 ! ! !
RP/0/0/CPU0:PE1# |
Can you explain me why in my conf if I configure a static route on IOS-XR 5.2.2
router static
vrf BGP-GREEN
10.0.10.0/24 2.2.2.2
I cannot see it in routing table?
RP/0/0/CPU0:ASBR-11#sh route vrf BGP-GREEN
B 10.0.10.0/24 [200/2] via 2.2.2.2 (nexthop in vrf default), 00:24:32
C 192.168.17.0/30 is directly connected, 00:25:30, GigabitEthernet0/0/0/2.10
L 192.168.17.1/32 is directly connected, 00:25:30, GigabitEthernet0/0/0/2.10
Found by my own:
It wanted the "vrf default" for the next hop (10.0.10.0/24 vrf default 2.2.2.2)
