tepatel
Configuring and Troubleshooting ISRs with HWIC-2CE1T1-PRI with PVDM2-24DM for incoming async calls
Introduction
Now we all know that ISRs are becoming more and more popular for customer deployments. In many environments, customer need to configure an ISRs that can accept incoming calls from both Async and ISDN users. Such a setup is commonly used to provide network connectivity to users who travel and are telecommuters, and also for Small Office-Home Office (SOHO) sites.
As we all know that  many customers are migrating from their old NM-xCTE1-PRI modules to HWICs and VWICs because NM-xCTE1-PRI modules are End-Of-Sale as of December 29, 2008. Pl. visit following url for EOS announcements and migration path.
https://www.cisco.com/en/US/prod/collateral/routers/ps5855/eol_c51_484362.html
That said, HWICs are the perfect replacements for old NMs for data calls.  This document describes how to configure an Access Server to accept incoming Async calls on ISDN T1 PRI circuits. The configuration provides the minimum setup required for the Integrated Service Routers ( ISRs) to accept the call. You can add additional features to this configuration based on your needs.
Topology :
3845-1#sh    sh ver
Cisco IOS Software, 3800 Software (C3845-ADVENTERPRISEK9-M), Version 12.4(24)T1, RELEASE SOFTWARE (fc3)
<snip>
3845-1#sh run
Building configuration...
Current configuration : 3183 bytes
version 12.4
service internal
hostname 3845-1
boot-start-marker
boot-end-marker
card type t1 0 2
!---Need to define a card type about the use of HWIC-2TE1-PRI card to be a T1 card or a !---E1 card. Here we are using it as a T1 card.
logging message-counter syslog
logging buffered 65535
enable secret 5 $1$clc3$GfelyWY1QQs6bCR4lxwl..
no aaa new-model
network-clock-participate wic 0
!--- Allow other WICs modules to drive the clock from the selected T1 line
network-clock-select 1 T1 0/2/0
dot11 syslog
ip source-route
ip cef
no ip domain lookup
no ipv6 cef
isdn switch-type primary-5ess
voice-card 0
username 1811-1 password 0 cisco
username 1800-1 password 0 cisco
username Param password 0 cisco
archive
log config
  hidekeys
controller T1 0/2/0
cablelength long 0db
pri-group timeslots 1-24
!--- For T1 PRI scenarios, all 24 T1 timeslots are assigned as
!--- ISDN PRI channels. The router now automatically creates the
!--- corresponding D-channel: interface Serial 0/2/0:23.
!--- Framing for this T1 is Extended Super Frame (ESF) and linecode is !--- B8ZS is default. Obtain these information from the Telco.
controller T1 0/2/1
interface Loopback1
ip address 100.1.1.1 255.255.255.0
!--- The IP pool for ISDN users is in this subnet.
!--- The routes for all ISDN clients are summarized and
!--- propagated to the backbone instead of 254 routes.
interface GigabitEthernet0/0
ip address 172.16.163.203 255.255.255.224
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/1
no ip address
shutdown
duplex auto
speed auto
media-type rj45
interface Serial0/1/0:23
no ip address
encapsulation ppp
isdn incoming-voice voice
interface Serial0/2/0:23
ip unnumbered Loopback1
encapsulation ppp
dialer-group 1
isdn incoming-voice modem
!--- All incoming voice calls on this T1 are sent to the modems.
!--- This command is required if this T1 is to accept async modem calls.
peer default ip address pool My-IP
interface Integrated-Service-Engine4/0
no ip address
shutdown
!Application: NME-APA running on BRYCE
no keepalive
interface Group-Async1
!--- This group-async interface is the configuration template for all !--- modems.  You need not configure individual async interfaces
!--- because you can clone the interfaces from one managed copy.
!--- A Loopback interface is always up/up. So, unnumber the Loopback
!--- interface for stability.
encapsulation ppp
dialer in-band
dialer idle-timeout 300 either
!--- Idle Timeout is defined as 300 secs which is 5 mins.
dialer-group 1
!--- Interesting traffic is defined in dialer-list 1.
!--- Note: The specified dialer-group number must be the same as the   !--- dialer-list number. In this example, the number is defined as "1".
async mode dedicated
!--- Clients are assigned addresses from the IP address pool named
!--- My-IP which needs to be configured later in the config.
ppp authentication chap callin
!--- Use CHAP authentication.
ppp multilink
!--- Configure the interface to use multilink.
!--- Without this command multilink is NOT negotiated.
!--- This command is needed to bind more than one calls from the same
!--- user together.
group-range 0/514 0/537
!--- Modems 0/514 through 0/537 are members of this group async
!--- interface
ip local pool My-IP 100.1.1.2 100.1.1.100
!--- IP address pools for dialin clients.
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 172.16.163.193
ip http server
no ip http secure-server
voice-port 0/1/0:23
mgcp fax t38 ecm
mgcp behavior g729-variants static-pt
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
password cisco
login
line 258
no activation-character
no exec
transport preferred none
transport input all
transport output lat pad telnet rlogin lapb-ta mop udptn v120 ssh
line 0/514 0/537
modem InOut
!--- Support incoming and outgoing modem calls.
transport input all
autoselect during-login
! ---  Displays the username:password prompt after modems connect.
autoselect ppp
!--- Automatically launches PPP if the router detects incoming PPP
!--- packets. Without this command the dialin client must manually
!--- launch PPP (from Exec mode).
line vty 0 4
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
line vty 5 10
exec-timeout 60 0
privilege level 15
password cisco
logging synchronous
login
scheduler allocate 20000 1000
end
3845-1#
3845-1#
3845-1#
3845-1#
3845-1#
end
3845-1# sh diag
3845 Backplane EEPROM:
<snip>
           PVDM Slot 1:
            24 port PVDMII digital modem PVDM daughter card
            Hardware Revision        : 2.0
            Part Number              : 73-10101-03
            Board Revision           : 02
            Deviation Number         : 0-0
            Fab Version              : 02
            PCB Serial Number        : FHH10100018
            RMA Test History         : 00
            RMA Number               : 0-0-0-0
            RMA History              : 00
            Processor type           : 00
            Product (FRU) Number     : PVDM2-24DM
            Version Identifier       : V01
            EEPROM format version 4
            EEPROM contents (hex):
              0x00: 04 FF 40 04 8F 41 02 00 82 49 27 75 03 42 30 32
              0x10: 80 00 00 00 00 02 02 C1 8B 46 48 48 31 30 31 30
              0x20: 30 30 31 38 03 00 81 00 00 00 00 04 00 09 00 CB
              0x30: 8A 50 56 44 4D 32 2D 32 34 44 4D 89 56 30 31 20
              0x40: D9 02 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF
              0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
              0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
            <snip>
            WIC Slot 2:
            2 port channelized and PRI T1/E1 HWIC
            Hardware Revision        : 0.0
            Top Assy. Part Number    : 800-27137-02
            Part Number              : 73-10363-03
            Board Revision           : A0
            Deviation Number         : 88300
            Fab Version              : 03
            PCB Serial Number        : FOC110300X6
            RMA History              : 00
            Product (FRU) Number     : HWIC-2CE1T1-PRI
            CLEI Code                : COUIAKHCAA
              0x00: 04 FF 40 05 2A 41 00 00 C0 46 03 20 00 6A 01 02
              0x10: 82 49 28 7B 03 42 41 30 88 00 01 58 EC 02 03 C1
              0x20: 8B 46 4F 43 31 31 30 33 30 30 58 36 03 00 81 00
              0x30: 00 00 00 04 00 89 56 30 31 20 CB 8F 48 57 49 43
              0x40: 2D 32 43 45 31 54 31 2D 50 52 49 C6 8A 43 4F 55
              0x50: 49 41 4B 48 43 41 41 D9 02 40 C1 FF FF FF FF FF
3845-1#show network-clocks
  Network Clock Configuration
  Priority      Clock Source    Clock State     Clock Type
     1          T1 0/2/0        GOOD            T1
!--- The clock is derived from primary T1 line in 0/2/0
    11          Backplane       GOOD            PLL
  Current Primary Clock Source
     1          T1 0/2/0        GOOD            T1
3845-1#sh isdn stat
Global ISDN Switchtype = primary-5ess
ISDN Serial0/2/0:23 interface
       dsl 0, interface ISDN Switchtype = primary-5ess
    Layer 1 Status:
        ACTIVE
    Layer 2 Status:
        TEI = 0, Ces = 1, SAPI = 0, State = MULTIPLE_FRAME_ESTABLISHED
    Layer 3 Status:
        0 Active Layer 3 Call(s)
    Active dsl 0 CCBs = 0
    The Free Channel Mask:  0x807FFFFF
    Number of L2 Discards = 0, L2 Session ID = 3
Troubleshooting Commands
Certain show commands are supported by the Output Interpreter Tool ( registered customers only) , which allows you to view an analysis of show command output.
Note: Before issuing debug commands, please see Important Information on Debug Commands.
·       debug dialer—displays DDR debugging information about the packets received on a dialer interface. This information can help to ensure there is interesting traffic that uses the dialer interface.
·       debug isdn q931—shows call setup and tear down of the ISDN network connection (Layer 3).
·       debug modem—displays modem line activity on an access server. The output displays when the modem line changes state.
·       debug modem csm—enables you to troubleshoot Call Switching Module (CSM) problems on routers with internal digital modems. With this command, you can trace the complete sequence of switching incoming and outgoing calls.
·       debug ppp negotiation—displays information on the PPP traffic and exchanges, and negotiates Link Control Protocol (LCP), Authentication, and Network Control Protocol (NCP). A successful PPP negotiation first opens the LCP state, then authenticates, and finally negotiates NCP. Multilink Parameters such as Maximum Receive Reconstructed Unit (MRRU) are established during LCP negotiation.
·       debug ppp authentication—displays PPP authentication protocol messages, including CHAP packet exchanges and Password Authentication Protocol (PAP) exchanges.
·       debug ppp error—displays protocol errors and error statistics associated with PPP connection negotiation and operation.
Sample debug Output for  Async call
*Sep  2 19:05:57.321: ISDN Se0/2/0:23 Q931: RX <- SETUP pd = 8  callref = 0x13B5
            Bearer Capability i = 0x9090A2
                        Standard = CCITT
                        Transfer Capability = 3.1kHz Audio
                        Transfer Mode = Circuit
                        Transfer Rate = 64 kbit/s
            Channel ID i = 0xA98381
                        Exclusive, Channel 1
            Progress Ind i = 0x8083 - Origination address is non-ISDN
            Calling Party Number i = 0x2183, '4089559247'
                        Plan:ISDN, Type:National
            Called Party Number i = 0x80, '83115'
                        Plan:Unknown, Type:Unknown
*Sep  2 19:05:57.321: ISDN Se0/2/0:23 Q931: Received SETUP  callref = 0x93B5 callID = 0x0004 switch = primary-5ess interface = User
*Sep  2 19:05:57.325: CSM: MODEM_REPORT from 0/2/0:0, call_id=0x4, event=0x1, cause=0x0, dchan_idb=0x67F90F14
*Sep  2 19:05:57.325: CSM: called_number '83115' modem_pool 6881CDB4 deny_call FALSE
*Sep  2 19:05:57.325: CSM: Next free modem = 0/517; statbits = 10020
*Sep  2 19:05:57.325: Modem 0/517 CSM: modem is allocated, modems free=-1
*Sep  2 19:05:57.325: Modem 0/517 CSM: Incoming call from 4089559247 to 83115, id 0x4
*Sep  2 19:05:57.325: Modem 0/517 CSM: (CSM_PROC_IDLE)<--ISDN_CALL
*Sep  2 19:05:57.325: ISDN Se0/2/0:23 Q931: TX -> CALL_PROC pd = 8  callref = 0x93B5
*Sep  2 19:05:57.325: ISDN Se0/2/0:23 Q931: TX -> ALERTING pd = 8  callref = 0x93B5
*Sep  2 19:05:57.325: ISDN Se0/2/0:23 Q931: TX -> CONNECT pd = 8  callref = 0x93B5
*Sep  2 19:05:57.337: ISDN Se0/2/0:23 Q931: RX <- CONNECT_ACK pd = 8  callref = 0x13B5
*Sep  2 19:05:57.337: CSM: MODEM_REPORT from 0/2/0:0, call_id=0x4, event=0x4, cause=0x0, dchan_idb=0x67F90F14
*Sep  2 19:05:57.337: Modem 0/517 CSM: MODEM_REPORT rcvd DEV_CONNECTED for call_id 0x4
*Sep  2 19:05:57.337: Modem 0/517 CSM: (CSM_PROC_MODEM_RESERVED)<--ISDN_CONNECTED
*Sep  2 19:05:57.337: Modem 0/517 CSMV12: SETUP(Answer) ISDN 0/2:0
*Sep  2 19:05:57.337: Modem 0/517 CSMV12: configured for Answer(Mu-law) mode, with Null signaling, 0x0 tone detection
*Sep  2 19:05:57.337: Modem 0/517 CSMV12: INIT(Answer) ISDN 0/2:0
*Sep  2 19:05:57.337: %ISDN-6-CONNECT: Interface Serial0/2/0:0 is now connected to 4089559247 N/A
3845-1(config-if)#
*Sep  2 19:05:57.369: CSM: csm_modem_event called
*Sep  2 19:05:57.369: Modem 0/517 CSM: (CSM_PROC_WAIT_FOR_CARRIER)<--CSM_EVENT_MODEM_SETUP
3845-1(config-if)#
*Sep  2 19:06:14.729: CSM: csm_modem_event called
*Sep  2 19:06:14.729: Modem 0/517 CSM: (CSM_PROC_WAIT_FOR_CARRIER)<--MODEM_CONNECTED
*Sep  2 19:06:14.733: Modem 0/517 CSMV12: CONNECT at 26400/28800 (Tx/Rx), V.34, LAP-M, V44
*Sep  2 19:06:14.741: TTY0/517: DSR came up
*Sep  2 19:06:14.741: TTY0/517: no timer type 1 to destroy
*Sep  2 19:06:14.741: TTY0/517: no timer type 0 to destroy
*Sep  2 19:06:14.741: TTY0/517: no timer type 2 to destroy
*Sep  2 19:06:14.741: tty0/517: Modem: IDLE->(unknown)
*Sep  2 19:06:16.741: %LINK-3-UPDOWN: Interface Async0/517, changed state to up
*Sep  2 19:06:16.741: As0/517 PPP: Using dialer call direction
*Sep  2 19:06:16.741: As0/517 PPP: Treating connection as a callin
*Sep  2 19:06:16.741: As0/517 PPP: Session handle[40000035] Session id[1]
*Sep  2 19:06:16.741: As0/517 PPP: Phase is ESTABLISHING, Passive Open
*Sep  2 19:06:16.741: As0/517 LCP: State is Listen
*Sep  2 19:06:16.769: As0/517 LCP: I CONFREQ [Listen] id 4 len 20
*Sep  2 19:06:16.769: As0/517 LCP:    ACCM 0x000A0000 (0x0206000A0000)
*Sep  2 19:06:16.769: As0/517 LCP:    MagicNumber 0x33B55A2B (0x050633B55A2B)
*Sep  2 19:06:16.769: As0/517 LCP:    PFC (0x0702)
*Sep  2 19:06:16.769: As0/517 LCP:    ACFC (0x0802)
*Sep  2 19:06:16.769: As0/517 PPP: Authorization required
*Sep  2 19:06:16.769: As0/517 LCP: O CONFREQ [Listen] id 1 len 25
*Sep  2 19:06:16.769: As0/517 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  2 19:06:16.769: As0/517 LCP:    MagicNumber 0x24714CC4 (0x050624714CC4)
*Sep  2 19:06:16.769: As0/517 LCP: O CONFACK [Listen] id 4 len 20
*Sep  2 19:06:16.969: As0/517 LCP: I CONFACK [ACKsent] id 1 len 25
*Sep  2 19:06:16.969: As0/517 LCP:    ACCM 0x000A0000 (0x0206000A0000)
*Sep  2 19:06:16.969: As0/517 LCP:    AuthProto CHAP (0x0305C22305)
*Sep  2 19:06:16.969: As0/517 LCP:    MagicNumber 0x24714CC4 (0x050624714CC4)
*Sep  2 19:06:16.969: As0/517 LCP:    PFC (0x0702)
*Sep  2 19:06:16.969: As0/517 LCP:    ACFC (0x0802)
*Sep  2 19:06:16.969: As0/517 LCP: State is Open
*Sep  2 19:06:16.969: As0/517 PPP: Phase is AUTHENTICATING, by this end
*Sep  2 19:06:16.969: As0/517 CHAP: O CHALLENGE id 1 len 27 from "3845-1"
*Sep  2 19:06:17.173: As0/517 CHAP: I RESPONSE id 1 len 27 from "1800-1"
*Sep  2 19:06:17.173: As0/517 PPP: Phase is FORWARDING, Attempting Forward
*Sep  2 19:06:17.173: As0/517 PPP: Phase is AUTHENTICATING, Unauthenticated User
*Sep  2 19:06:17.173: As0/517 PPP: Sent CHAP LOGIN Request
*Sep  2 19:06:17.173: As0/517 PPP: Received LOGIN Response PASS
*Sep  2 19:06:17.173: As0/517 PPP: Phase is AUTHENTICATING, Authenticated User
*Sep  2 19:06:17.173: As0/517 PPP: Sent LCP AUTHOR Request
*Sep  2 19:06:17.173: As0/517 PPP: Sent IPCP AUTHOR Request
*Sep  2 19:06:17.173: As0/517 LCP: Received AAA AUTHOR Response PASS
*Sep  2 19:06:17.173: As0/517 IPCP: Received AAA AUTHOR Response PASS
*Sep  2 19:06:17.173: As0/517 CHAP: O SUCCESS id 1 len 4
*Sep  2 19:06:17.173: As0/517 PPP: Phase is UP
*Sep  2 19:06:17.173: As0/517 IPCP: O CONFREQ [Closed] id 1 len 10
*Sep  2 19:06:17.173: As0/517 IPCP:    Address 100.1.1.1 (0x030664010101)
*Sep  2 19:06:17.173: As0/517 PPP: Process pending ncp packets
*Sep  2 19:06:17.349: As0/517 IPCP: I CONFREQ [REQsent] id 1 len 10
*Sep  2 19:06:17.349: As0/517 IPCP:    Address 0.0.0.0 (0x030600000000)
3845-1(config-if)#
*Sep  2 19:06:17.349: As0/517 AAA/AUTHOR/IPCP: Start.  Her address 0.0.0.0, we want 0.0.0.0
*Sep  2 19:06:17.349: As0/517 AAA/AUTHOR/IPCP: Done.  Her address 0.0.0.0, we want 0.0.0.0
*Sep  2 19:06:17.349: As0/517 IPCP: Pool returned 100.1.1.2
*Sep  2 19:06:17.349: As0/517 IPCP: O CONFNAK [REQsent] id 1 len 10
*Sep  2 19:06:17.349: As0/517 IPCP:    Address 100.1.1.2 (0x030664010102)
*Sep  2 19:06:17.529: As0/517 IPCP: I CONFREQ [REQsent] id 2 len 10
*Sep  2 19:06:17.529: As0/517 IPCP:    Address 100.1.1.2 (0x030664010102)
*Sep  2 19:06:17.529: As0/517 IPCP: O CONFACK [REQsent] id 2 len 10
*Sep  2 19:07:17.609: As0/517 IPCP: I CONFACK [ACKsent] id 17 len 10
*Sep  2 19:07:17.609: As0/517 IPCP:    Address 100.1.1.1 (0x030664010101)
*Sep  2 19:07:17.609: As0/517 IPCP: State is Open
*Sep  2 19:07:17.609: As0/517 IPCP: Install route to 100.1.1.2
*Sep  2 19:07:17.609: As0/517 IPCP: Add link info for cef entry 100.1.1.2
3845-1#
3845-1#
3845-1#
3845-1#
3845-1#sh users
    Line       User       Host(s)              Idle       Location
   0 con 0                1.1.1.1                 2d22h
   tty 0/531    Param      Async interface      00:00:04   PPP: 100.1.1.2
*706 vty 0                idle                 00:00:00 10.1.1.1
  Interface    User               Mode         Idle     Peer Address
3845-1#sh caller user Param detailed
  User: Param, line tty 0/517, service Async
        Active time 00:01:20
  Timeouts:    Limit     Remaining Timer Type
  TTY: Line 0/531, running PPP on As0/531
  Line: Baud rate (TX/RX) is 115200/115200, no parity, 2 stopbits, 8 databits
  Status: Ready, Active, No Exit Banner, Async Interface Active
  Capabilities: Modem Callout, Modem RI is CD,
                Line usable as async interface, Integrated Modem
  Modem State: Ready
  User: Param, line As0/531, service PPP
        Connected for 00:01:18, Idle for 00:01:18
               00:05:00  00:03:41  Dialer idle
  PPP: LCP Open, multilink Closed, CHAP (<-), IPCP
  LCP: -> peer, ACCM, AuthProto, MagicNumber, PCompression, ACCompression
              EndpointDisc
       <- peer, ACCM, MagicNumber, PCompression, ACCompression
  NCP: Open IPCP
  IPCP: <- peer, Address
        -> peer, Address
  Dialer: Connected, inbound
          Type is IN-BAND ASYNC, group As0/531
  IP: Local 100.1.1.1, remote 100.1.1.2
  Counts: 222 packets input, 3182 bytes, 0 no buffer
          0 input errors, 0 CRC, 0 frame, 0 overrun
          39 packets output, 547 bytes, 0 underruns
3845-1#sh dialer map
Dynamic dialer map ip 100.1.1.2   name Param     () on As0/531
Abhijit Ashok Aphale
Community Member
Can we move our AS5350 RAS setup on ISR-G2 Series will it be efficient to handle , below are our existing modules on the AS chassis
AS5350-AC
AS5350 NP108 DFC
AS5350 E1 8 PRI DFC
Community Member
I am testing the RAS setup on PRI line with :
Cisco2911
HWIC-2CE1T1-PRI
PVDM2-36
Now incoming ISDN calls are coming through the router however getting issue on Async calls.
I am not able to get any debug output for incoming and out going calls.
Below is related conf on router
ip unnumbered Dialer1
dialer in-band
dialer rotary-group 1
async mode interactive
no keepalive
ppp multilink
group-range 0/195 0/230
interface Dialer1
ip address 10.5.230.2 255.255.255.0
encapsulation ppp
dialer in-band
dialer idle-timeout 600
dialer map ip 10.5.230.1 name testras modem-script myscript broadcast 0XXXXXXX
dialer-group 1
Please suggest
