SunilKhanna
    Introduction
    As per RFC 4291, a single interface of a router can be configured with multiple IPv6 addresses. All Cisco IOS release with IPv6 support, a router interface can be configured with multiple IPv6 global addresses within the same prefix.
    Background
    In this document, interface FastEthernet 0/0 of Cisco Router 3745 is configured with multiple IPv6 addressed with command "ipv6 address".
    Note: The configuration is tested on Cisco 3745 router running C3745-ADVIPSERVICESK9-M, Version 12.4(25d).
    Configuration
    R1#conf t
    Enter configuration commands, one per line.  End with CNTL/Z.
    R1(config)#int fa 0/0
    R1(config-if)#ipv6 address 2011:ABC1:9:F11::/64 eui-64
    R1(config-if)#ipv6 address 2011:ABC1:10:F11::/64 eui-64
    R1(config-if)#ipv6 address 2011:ABC1:11:F11::/64 eui-64
    R1(config-if)#ipv6 address 2011:ABC1:12:F11::/64 eui-64
    Verification
    We can verify the IPv6 configuration on the interface by command "show run interface fa 0/0" or by command "show ipv6 interface". Here is an example of the two commands.
    R1#sh run int fa 0/0
    Building configuration...
    Current configuration : 257 bytes
    interface FastEthernet0/0
    no ip address
    duplex auto
    speed auto
    ipv6 enable
    end
    R1#sh ipv6 int
    FastEthernet0/0 is up, line protocol is up
      IPv6 is enabled, link-local address is FE80::C600:13FF:FE68:0
      Global unicast address(es):
        2011:ABC1:9:F11:C600:13FF:FE68:0, subnet is 2011:ABC1:9:F11::/64 [EUI]
        2011:ABC1:10:F11:C600:13FF:FE68:0, subnet is 2011:ABC1:10:F11::/64 [EUI]
        2011:ABC1:11:F11:C600:13FF:FE68:0, subnet is 2011:ABC1:11:F11::/64 [EUI]
        2011:ABC1:12:F11:C600:13FF:FE68:0, subnet is 2011:ABC1:12:F11::/64 [EUI]
      Joined group address(es):
        FF02::1
        FF02::2
        FF02::1:FF68:0
      MTU is 1500 bytes
      ICMP error messages limited to one every 100 milliseconds
      ICMP redirects are enabled
      ND DAD is enabled, number of DAD attempts: 1
      ND reachable time is 30000 milliseconds
      ND advertised reachable time is 0 milliseconds
      ND advertised retransmit interval is 0 milliseconds
      ND router advertisements are sent every 200 seconds
      ND router advertisements live for 1800 seconds
      Hosts use stateless autoconfig for addresses.
    References
    Implementing IPv6 Addressing and Basic Connectivity
