Santosh Sharma
EEM Script to reload the Linecard incase "%PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp" Pattern appears in the log
Problem:
With release 4.2.3 on asr9000 series routers, the interfaces on the Linecard goes down if "%PLATFORM-DIAGS-3-PUNT_FABRIC_DATA_PATH_FAILED : Set|online_diag_rsp" appears in the syslog.
Solution:
Reload the linecard incase this log appears in the syslog
Router's config:
event manager directory user policy harddisk:/scripts/
event manager policy fabric_retrain_v1.tcl username event_manager_user
persist-time 3600
group root-system
group cisco-support
aaa authorization commands eem-method none
aaa authorization eventmanager default local
vty-pool eem 100 105 line-template eem-template
  line template eem-template
More Scripts: EEM Script Repository
Yong Zhao
Good example! Thanks sharing!
