TCC_2
Level 10
Level 10
Core Issue
A Cisco router can be configured to accept a break sequence to enter ROM Monitor (ROMmon) during normal operation.
Resolution
If the router boots to normal execution mode and ignores the break sequence, issue the config-register 0x2012 command from configuration mode. Then reload the router. The new config register value will enable you to send the break signal from the normal router execution mode. This allows you to go ROMMON mode directly from the normal execution mode.
For more options, refer to Configuration Register.
