kramesh
This document describes step by step procedure to Design and Deploy SDWAN Router and Firewall on NFVIS platform.
Hardware and Software used in this guide
  • DNAC 1.3.3.0
  • NFVIS Version 3.12.3
  • ENCS5408/K9
  • vedge-cloud 19.1.0
Prerequisites
NFVIS installed on (supported) hardware and access to the local management Web-GUI.
DNAC installed on appliance and access to the management GUI.
Step-by-step instructions
This document assumes that Sites, Network Settings are created and available in the DNAC system.
Upload Images into image repository
Import vedge-cloud sdwan and paloalto firewall packages onto DNAC image repository
upload vedge-cloudupload vedge-cloud
upload paloalto firewall package for NFVISupload paloalto firewall package for NFVIS
Select version for use in design and deploymentSelect version for use in design and deployment
Create vBranch Network Design
Platform and WANPlatform and WAN
For comparison, design creation in DNAC1.2.5 and 1.3.3.0 release is shown. DNAC 1.3.3.0 provides the new and updated design canvas.
DNAC 1.3.3.0 Customize Service chain connectionsDNAC 1.3.3.0 Customize Service chain connections
DNAC 1.2.5 Select Network FunctionsDNAC 1.2.5 Select Network Functions
Add Custom NetworkAdd Custom Network
Switch ConfigSwitch ConfigCustom Config TemplatesCustom Config TemplatesDesign CompleteDesign CompleteAssociate Design and Site(s)Associate Design and Site(s)
Configure vManage access info in DNAC
vManage info in DNAC settingsvManage info in DNAC settings
Discover device and add to Inventory
Discover DeviceDiscover Device
Provision vBranch
Provision workflow startProvision workflow start
Provision Router WAN AddressProvision Router WAN Address
Complete bootstrap configuration for VNFsComplete bootstrap configuration for VNFs
Verify design and DeployVerify design and Deploy
DNAC starts deploying design with configurationDNAC starts deploying design with configuration
Provision complete SuccessProvision complete Success
