CscTsWebDocs
Community Member
    Introduction
    This document explains the NAT Box to Box High Availability feature overview of ISRG2 Router.
    Background of This Feature
    The Stateful NAT was available with IOS as a redundancy feature of the router that uses Dynamic NAT.
    However, the IOS versions after 15.0M no longer support the Stateful NAT.
    In addition, the Stateful NAT feature will reach End-Of-Support on January 31, 2014.
    End-of-Sale and End-of-Life Announcement for the Cisco IOS Stateful Failover of Network Address Translation (SNAT)
    http://www.cisco.com/en/US/prod/collateral/iosswrel/ps6537/ps6586/ps6640/end_of_life_notice_c51-611706.html
    The above link introduces the Cisco ASA Adaptive Security Appliance high availability as Migration Options of the Stateful NAT.
    Later on, the NAT Box-to-Box High-Availability feature has been newly added to IOS 15.3(2)T or later.
    You can realize high-availability with NAT on ISR G2 Routers by using this feature as the Stateful NAT did.
    I will explain the feature overview, basic configuration/settings, and troubleshooting of NAT Box-to-Box High-Availability in the following sections.
    Feature Overview
    NAT Box to Box High Availability (NAT BtoB HA, hereinafter) is the feature designed to enhance the fault tolerance of the NAT router links or router itself in case of unexpected problems.
    In addition, asymmetric routing with Dynamic NAT is also supported.
    The NAT BtoB HA consists of two components: a function called Redundancy Group (RG) to control active-standby state and the Network Address Translation (NAT) function.
    Thus, you need to configure the two components (RG and NAT) for NAT BtoB HA.
    Due to the restrictions currently applicable, for example, ALG is only supported for the FTP application,
    please refer to the following document and verify the behavior thoroughly when you implement this feature.
    Restrictions for NAT Box-to-Box High-Availability Support
    http://www.cisco.com/en/US/docs/ios-xml/ios/ipaddr_nat/configuration/15-mt/iadnat-b2b-ha.html#reference_C93828C500774EA1A6C8C19313220C27
    As of now, NAT BtoB HA supports the following NAT features:
    Please note that interface overload options are not supported.
    -Simple Static NAT configuration
    -Extended Static NAT configuration
    -Network Static NAT configuration
    -Dynamic NAT and Port Address Translation (PAT) configuration
    -NAT inside source, outside source, and inside destination rules
    -NAT rules for Virtual Routing and Forwarding (VRF) instances to IP
    -NAT rules for VRF-VRF (within same VRF)
    Key Configuration Element for NAT BtoB HA
    You need to configure the following interfaces with NAT BtoB HA.
    Figure. 1 shows the conceptual diagram of the configuration.
    -NAT inside/outside interface
    -RG control interface (for exchange control information by RG)
    -RG data interface (for exchange NAT session data, etc.)
    -RG Asymmetric Routing (AR) interface (for forwarding AR packets from Standby to Active; optional)
    You can define RG Control/Data/AR interfaces in the same physical interface.
    Figure. 1
    NAT BtoB HA supports the (LAN-LAN) configuration that makes both the inside and outside NAT redundant as well as the (WAN-LAN) configuration that makes only the inside redundant.
    Figure. 2 is the topology of each configuration.
    Figure. 2
    Return to Top
    Basic Configuration
    This section introduces an example of basic configuration for LAN-LAN and WAN-LAN configuration respectively.
    Example: LAN-LAN Configuration
    This is a configuration example based on the topology shown at Figure. 3.
    Please note that you do not need to configure the HSRP settings (standby ip command, etc.) unlike the case of Stateful NAT.
    Figure. 3
    /// Router1 ///
    redundancy
     application redundancy
      group 1
       name RG1
       preempt
       priority 105
       control Ethernet0/1 protocol 1
       data Ethernet0/1
    interface Ethernet0/0
     ip nat inside
     ip virtual-reassembly in
     redundancy rii 100
     redundancy group 1 ip 192.168.1.254 exclusive decrement 100
    interface Ethernet0/1
     ip address 192.168.3.1 255.255.255.0
    interface Ethernet1/0
     ip address 192.168.2.1 255.255.255.0
     ip nat outside
     redundancy rii 101
     redundancy group 1 ip 192.168.2.254 exclusive decrement 100
    ip nat inside source static 192.168.1.3 192.168.2.3 redundancy 1 mapping-id 120
    /// Router2 ///
    redundancy
      group 1
       name RG1
       preempt
       data Ethernet0/1
     ip address 192.168.1.2 255.255.255.0
     ip nat inside
     redundancy rii 100
     ip address 192.168.3.2 255.255.255.0
     ip address 192.168.2.2 255.255.255.0
     ip nat outside
     redundancy rii 101
    Example: WAN-LAN Configuration
    This is a configuration example based on the topology shown at Figure. 4.
    I have also configured the following features, but they are optional.
    - RG Asymmetric-routing (*1)
    - OSPF for the WAN side routing protocol (*2)
    - Tracking an existence of Virtual IP (VIP) in the routing table and Redistributing a gateway's address to the routing protocol (OSPF) for the WAN network. (*3)
    Figure. 4
    /// Router1 ///
    redundancy
      group 1
       name RG1
       preempt
       priority 105
       data Ethernet0/1
       asymmetric-routing interface Ethernet0/1     (*1)
    track 100 ip route 192.168.1.254 255.255.255.255 reachability     (*3)
     ip nat inside
     redundancy rii 100
     ip address 10.1.1.1 255.255.255.0
     ip nat outside
     redundancy rii 101
     redundancy asymmetric-routing enable     (*1)
    router ospf 1    (*2)
     router-id 10.1.1.1
     redistribute static subnets
     network 10.0.0.0 0.255.255.255 area 0
    ip nat inside source static 192.168.1.3 10.10.10.10 redundancy 1 mapping-id 120
    ip route 10.10.10.10 255.255.255.255 Ethernet0/0 track 100    (*3)
    /// Router2 ///
    redundancy
      group 1
       name RG1
       preempt
       data Ethernet0/1
     ip nat inside
     redundancy rii 100
     ip address 10.2.2.2 255.255.255.0
     ip nat outside
     redundancy rii 101
    router ospf 1     (*2)
     router-id 10.2.2.1
    Logs for TAC Analysis
    Please get the following logs before opening a TAC service request if possible.
    show ip nat redundancy <RG-id>
    show ip nat translations redundancy <RG-id> [verbose]
    show redundancy application group <RG-id>
    show redundancy application protocol group <RG-id>
    show ip route
    show ip alias
    show ip cef
    show tech-support
    Please consider its impact when you get debug logs in production networks.
    debug ip nat [detailed]
    debug ip nat redundancy errors
    debug ip nat redundancy messages [[detailed] [errors ]]
    debug ip nat redundancy packets
    debug ip nat redundancy db [errors]
    debug ip nat redundancy cf
    debug ip nat redundancy rf [errors]
    If you want to clear the specific RG group session, issue the following commands:
    clear ip nat translation redundancy <RG-id> *
    clear ip nat translation redundancy <RG-id> forced
    For further detail, please refer to the following document in Cisco.com.
    IP Addressing: NAT Configuration Guide, Cisco IOS Release 15M&T
    Related Information
    Original Document:https://supportforums.cisco.com/ja/document/12049976
    Author: Toshiaki Kasakake
    Posted on January 8, 2014
    Paul Wishart
    This is a great article, but can HA-NAT be used to load balance traffic between two NAT routers, or can GLBP be run in conjunction with this?  If so, can you provide example configs with GLBP?
    Anton Kistruga
    Hello!
    Is there any method to do Box-to-Box NAT HA with 4-5 outside NAT addresses? I just try to do so with VRRP but in such case I have only 6 Mb/s of NAT performance on ISR-4431. Is there capability to configure 4-5 HA VIP addresses to the WAN without loss of performance?
    Thank you!
