Pulkit Nagpal
For general assessment of memory available, following two commands are used. From these command output you will be able to tell whether the platform memory utilization is normal or un-expected:
N7K-1-VDC2# show system resources
Load average: 1 minute: 0.11 5 minutes: 0.09 15 minutes: 0.14
Processes : 1241 total, 2 running
CPU states : 2.0% user, 3.4% kernel, 94.6% idle
Memory usage: 4115232K total, 3606556K used, 508676K free
Note: The “show system resources” command is used to display platform memory statistics.
For memory information per process for current VDC , following command is used:
N7k-3-VDC3# show processes memory
PID MemAlloc MemLimit MemUsed StackBase/Ptr Process
4662 52756480 562929945 150167552 bfffdf00/bfffd970 netstack
MemAlloc: Data Segement size
MemLimit: Maximum memory process can use
MemUsed: Virtual Memory
For a detailed assessment of platform memory utilization, use:
N7k-3-VDC3# show system internal kernel meminfo
MemTotal: 4115232 kB -------This is the total amount of memory in the system (4 GB in Sup 1)
MemFree: 263684 kB
Buffers: 82400 kB
Cached: 1817788 kB -------The memory used by the page cache
ShmFS: 1533324 kB
Allowed: 1028808 Pages
Free: 65921 Pages
Available: 164026 Pages -------Amount of free memory in pages
SwapCached: 0 kB
Active: 2080320 kB
Inactive: 1433752 kB
HighTotal: 3338960 kB
HighFree: 4092 kB
LowTotal: 776272 kB
LowFree: 259592 kB
SwapTotal: 0 kB
SwapFree: 0 kB
Dirty: 0 kB
Writeback: 0 kB
AnonPages: 1613748 kB
Mapped: 456088 kB  ------Memory mapped into page tables
Slab: 142884 kB --------Rough indication of kernel memory consumption
SReclaimable: 25556 kB
SUnreclaim: 117328 kB
PageTables: 32756 kB
Note: One page of memory is equivalent of 4 KB of memory.
Using above commands you can determine if the utilization is high due to page cache, process holding memory or Kernel.
For further troubleshooting:
For Page cache:
If Cached is high, you should check the file system utilization and determine what kind of files are using the file system:
N7K-1-VDC2# show system internal flash
Mount-on                  1K-blocks      Used   Available   Use%  Filesystem
/                            409600     43008      367616     11   /dev/root
/proc                             0         0           0      0   proc
/sys                              0         0           0      0   none
/isan                        409600    269312      140288     66   none
/var/tmp                     307200       876      306324      1   none
/var/sysmgr                 1048576    999424       49152      96   none
/var/sysmgr/ftp              307200     24576      282624      8   none
/dev/shm                    1048576    412672      635904     40   none
/volatile                    204800         0      204800      0   none
/debug                         2048        16        2032      1   none
/dev/mqueue                       0         0           0      0   none
/mnt/cfg/0                    76099      5674       66496      8   /dev/hda5
/mnt/cfg/1                    75605      5674       66027      8   /dev/hda6
/bootflash                  1796768    629784     1075712     37   /dev/hda3
/var/sysmgr/startup-cfg      409600     27536      382064      7   none
/mnt/plog                     56192      3064       53128      6   /dev/mtdblock2
/dev/pts                          0         0           0      0   devpts
/mnt/pss                      38554      6682       29882     19   /dev/hda4
/slot0                      2026608         4     2026604      1   /dev/hdc1
/logflash                   7997912    219408     7372232      3   /dev/hde1
/bootflash_sup-remote       1767480   1121784      555912     67   127.1.1.6:/mnt/bootflash/
/logflash_sup-remote        7953616    554976     6994608      8   127.1.1.6:/mnt/logflash/
For displaying contents of these sub-folders, use:
show system internal dir full directory path
for example: show system internal dir /bootflash
And, to delete a specific file use:
filesys delete full file path
For Kernel:
Contact Cisco TAC
For user processes:
N7K# show system internal processes memory
PID TTY STAT TIME MAJFLT TRS RSS VSZ %MEM COMMAND
4727 ? Ss 00:00:00 0 1549 123248 132832 2.9 /isan/bin/pixm
4728 ? Ssl 00:00:00 0 408 78388 143104 1.8 /isan/bin/routing-sw/mrib -m 4
6662 ? Ssl 00:00:05 0 2762 64024 144396 1.5 /isan/bin/routing-sw/netstack /isan/etc/routing-sw/pm.cfg
4538 ? Ssl 00:00:00 0 2762 60448 211664 1.4 /isan/bin/routing-sw/netstack /isan/etc/routing-sw/pm.cfg
5865 ? Ssl 00:00:01 0 2762 60416 113320 1.4 /isan/bin/routing-sw/netstack /isan/etc/routing-sw/pm.cfg
6395 ? Ssl 00:00:00 0 2762 52008 105552 1.2 /isan/bin/routing-sw/netstack /isan/etc/routing-sw/pm.cfg
4271 ? Ssl 00:00:00 0 609 49812 61420 1.2 /isan/bin/routing-sw/urib
7879 ? Ssl 00:00:00 0 1909 44800 90508 1.0 /isan/bin/routing-sw/bgp -t 64000
5696 ? Ssl 00:00:17 0 337 44696 55252 1.0 /isan/bin/routing-sw/clis -cli /isan/etc/routing-sw/cli
5333 ? Ssl 00:00:14 0 337 44652 55208 1.0 /isan/bin/routing-sw/clis -cli /isan/etc/routing-sw/cli
4182 ? Ssl 00:00:15 0 337 44648 55204 1.0 /isan/bin/routing-sw/clis -cli /isan/etc/routing-sw/cli
6076 ? Ssl 00:00:14 0 337 44624 55284 1.0 /isan/bin/routing-sw/clis -cli /isan/etc/routing-sw/cli
6825 ? Ssl 00:00:00 0 1402 44576 84020 1.0 /isan/bin/routing-sw/pim -t
4268 ? Ssl 00:00:00 0 363 27132 38896 0.6 /isan/bin/routing-sw/u6rib
4732 ? Ssl 00:00:00 0 404 25220 65360 0.6 /isan/bin/routing-sw/m6rib
4726 ? S<s 00:00:00 0 144 25208 30188 0.6 /isan/bin/pixmc
Increase in the utilization for a specific process will indicate a problem. Troubleshooting process afterward depends on the culprit process.
Note: The above output when taken from any VDC will show content of all VDCs.
Memory threshold for releases prior to 4.2(4):
  • 70% Minor
  • 80% Critical
  • 90% Major
For 4.2(4) and later releases:
  • 85% Minor
  • 90% Critical
  • 95% Major
These thresholds can be configured by using command:
system memory-thresholds minor percentage severe percentage critical percentage
The command that can be used to check memory alert info is:
Show system internal memory-alert-log
Ariq Ibne Aziz
Level 3
Level 3
hi
my N3K shows this output. and my SIEM shows that the memory utilization is high 79%. Should i be worried or not ?
SVR-SW-Secondary(config)# show system resources
Load average: 1 minute: 0.18 5 minutes: 0.30 15 minutes: 0.28
Processes : 461 total, 1 running
CPU states : 3.00% user, 1.25% kernel, 95.75% idle
CPU0 states : 0.00% user, 0.00% kernel, 100.00% idle
CPU1 states : 3.03% user, 0.00% kernel, 96.96% idle
CPU2 states : 7.92% user, 2.97% kernel, 89.10% idle
CPU3 states : 0.99% user, 0.99% kernel, 98.01% idle
Memory usage: 4032072K total, 3215764K used, 816308K free
