HatemCisco2010
Community Member
Hello ,
does any one have an idea about switch ports going on err-disabled state  suddenly
In fact , we have Switch CISCO 3560 POE -48  to each port is connected an IP phone  with embedded switch connected to a PC
Sometimes we find the port down   , when we  enter the sh interface command whe have :
FastEthernet1/0/5 is down, line protocol is down (err-disabled)
  Hardware is Fast Ethernet, address is 0024.c318.2387 (bia 0024.c318.2387)
  MTU 1500 bytes, BW 10000 Kbit, DLY 1000 usec,
  Keepalive set (10 sec)
  Auto-duplex, Auto-speed, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 9w4d, output 9w4d, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     16375217 packets input, 3101173312 bytes, 0 no buffer
     Received 250969 broadcasts (0 multicasts)
     0 watchdog, 226491 multicast, 0 pause input
     189641431 packets output, 25371607307 bytes, 0 underruns
     0 output errors, 24 collisions, 1 interface resets
You can find here the port configuration on the switch
interface FastEthernet1/0/5
switchport access vlan 1700
switchport mode access
switchport voice vlan 1500
spanning-tree portfast
spanning-tree bpduguard enable
Bobby Thekkekandam
Hi Hatem,
show interface Fa 1/0/5  status err-disabled
will give you the reason for why the port was errdisabled.
HTH,
BT
