jeaves@cisco.com
Introduction
Prior to release 1.3.3, Extended Node configuration was not all automated, segmentation was static per VLAN and not dynamically assigned per endpoint and SGTs were not assigned on the Extended Nodes themselves so East-West traffic on an individual Node was not enforced.
Release 1.3.3 introduces Policy Extended Node:
  • As well as the AAA and interface configuration being orchestrated on the Policy Extended Node, ISE assigns both the VLAN and SGT upon authentication/authorization.
  • This allows full fabric segmentation to be extended down to the Policy Extended Node.
  • Inline Tagging is enabled between the Policy Extended Node and the connected Fabric Edge.
  • Supported only on the IE3400 and IE3400H (Note: Cisco DNA Center 2.1.2.x extends PEN functionality to most Catalyst 9000 Series Switching platforms: 9200/L, 9300/L, 9400, 9500/H)
  • Multicast support on Policy Extended node enables endpoints such as video surveillance to be part of the fabric
Starting from Cisco SD-Access 1.3.3 release, Policy Extended Node for the IE3400 and IE3400H is supported connected to Fabric Edge Nodes. In the backend Autoconf is used for Host-onboarding.
Previously enabled “Extended Node” with reduced functionality will continue to be supported on the IE3300, IE4000, IE4010, IE5000, 3560-CX and the Catalyst Digital Building (CDB) switches.
Note: Policy Extended node should not have any existing configuration for the plug and play to work. If there is any existing configuration please do “write erase” and reload the Policy Extended Node so that it is at this prompt:
Would you like to enter the initial configuration dialog? [yes/no]:
Note2: Fabric Edge switches require from release 16.12.2 for any 1.3.3 Cisco DNA Center code. The IE3400/IE3400H Policy Extended Node requires from release 17.1.1
Note3: When connecting a switch with MTU restrictions to an SDA configuration using ISE on AWS, you need to be careful about the MTU. If necessary, you need to lower the MTU of the ISE.
A device is onboarded according to the license of its Extended Node neighbor and its own license:
  • If the neighbor is operating with an Essentials license, the device is onboarded as a standard Extended Node, regardless of its license.
  • If the neighbor is operating with an Advantage license (network-advantage with or without dna-advantage addon), the device is onboarded as a standard Extended Node if it has an Essentials license.
  • If the neighbor is operating with an Advantage license (network-advantage with dna-advantage addon), the device is onboarded as a Policy Extended Node if it has an Advantage license (network-advantage with dna-advantage addon).
  • If the device has more than one neighbor, and those neighbors have different license levels, the device is onboarded as a standard Extended Node, regardless of its license.
Licensing information: Cisco Catalyst and Cisco DNA Software Subscription Matrix for Switching
Please see official CCO documentation for latest Extended Node updates. For example, Catalyst Center 2.3.7 user guide.
Configure Cisco DNA Center for Policy Extended Node
Site Level Credentials
Make sure credentials in Design > Network Settings > Device Credentials are applied to every site and not just at the Global level. Navigate to the site, select the credentials and hit SAVE.
IP Pools for Policy Extended Node
Make sure IP Address pool for Policy Extended Node is configured. This has to be an IPv4 Pool.
Navigate to Design > Network Settings > IP Address Pools > Global and add ExtNode Pool(s).
Reserve the IP Address Pool(s) under the site/building that the Policy Extended Node will be added to.
Create Port Channel
From release 1.3, SD-Access supports port channel between Policy Extended Node and Fabric Edge. Policy Extended Node and Fabric Edge device is always connected using port-channel (even for single port).
If any fabric level Authentication mode is set, user needs to create a PAGP port-channel on fabric edge in port-channel tab. For no-authentication mode, port-channel will be created automatically.
Follow the following steps if the auth mode is something other than no-authentication to create the port-channel manually:
1) Click on the Fabric Edge device to which the Policy Extended Node is connected and go to port-channel tab, providing the port(s) information and selecting the protocol
2) In the Port Channel tab, click on Create PortChannel
3) In the Port Channel create section, select the interface that is connected to the Policy Extended Node that you want to be part of the port channel.
Note: Even if only one interface is connected to the Policy Extended Node from FE, port channel still needs to be created.
There are three options. For the IE3400/IE3400H choose PAGP.
Please verify that port channel gets created successfully
Host Onboarding
1) Configure Auth Template as “No Authentication” for the Policy Extended Node to come up automatically when connected
If the Auth Template is configured for anything other than “No Authentication” then follow the below steps:
2) Select IP Pool for Policy Extended Node’s management IP in Provision > Fabric > Host Onboarding > Infra_VN.
The Policy Extended Node will be part of the INFRA_VN for Cisco DNA Center’s PnP host onboarding feature.  Click on the INFRA-VN.
Click on Add in the INFRA_VN to add ExtNode Pool created during IP Pool reservation
Click on the Pool Type and select Extended and click Update.
Assign Port - Fabric Edge to Policy Extended Node
Now we need to assign the port channel as an extended node.
1) To assign the port channel as a extended node, go to Provision > Fabric > Host Onboarding > Select Port Assignment > FE connected to the Policy Extended Node.
You should see the port channel that you just created
2) Click on Port-channel1 and click on Assign to assign it as an extended node
3) In the Port Assignments, select extended node for the Connected Device Type from the drop down menu and click on Update
4) Click on Save to push the configuration to the Fabric Edge device and start the Policy Extended Node bringup
DHCP Requirements
The Policy Extended Node requires an IP address provided by a DHCP server to start the PNP process. This request is forwarded in the underlay via the INFRA_VN. As well as providing the management IP of the Policy Extended Node, the DHCP server must provide required information to allow the Policy Extended Node to contact Cisco DNA Center to start the PNP process.
Example DHCP scopes are shown below which includes Option 43 and details information required to contact Cisco DNA Center.
Option 43 includes three type-length-values (TLV). The first value is 5A1D;B2;K4; which specifies the PNP option. The second is the Cisco DNA Center IP address. The third is the port which could be 80 or 443. In total an example is 5A1D;B2;K4;I<Cisco DNA Center IP>;J80;
Example DHCP Scope for Linux/Unix Systems
option dnac code 43 = string;
subnet 10.4.6.0 netmask 255.255.255.0 {
  range 10.4.6.100 10.4.6.200;
  option domain-name-servers 10.1.100.2;
  option domain-name "kernow.com";
  option subnet-mask 255.255.255.0;
  option routers 10.4.6.254;
  option broadcast-address 10.4.6.255;
  option dnac "5A1D;B2;K4;I10.1.150.20;J80;";
  default-lease-time 3600;
  max-lease-time 7200;
N.B 10.1.150.20 is the Cisco DNA Center IP address.
Example DHCP Scope for Windows Systems
For Windows systems, the same Option 43 ASCII content is required, you just need to enter the equivalent Hex values for the characters, as shown below
N.B. 10.1.200.26 is the Cisco DNA Center IP address.
Example DHCP Scope for Cisco Routers/Switches
ip dhcp pool ExtendedNodeNW
 network 192.168.17.0 255.255.255.0
 option 43 ascii 5A1D;B2;K4;I10.5.132.10;J80;
 default-router 192.168.17.1
Here, DHCP pool name is ExtendedNodeNW, IP Pool range is 192.168.17.0/24, and in option 43, 10.5.132.10 is the Cisco DNA Center IP Address.
Verify Policy Extended Node Bringup
If the IE3400/IE3400H has previously been used for any PNP purposes, the following may be required to completely erase the configuration:
del /f flash:private-config.text
del /f sdflash:private-config.text
del /f flash:config.text
del /f sdflash:config.text
del /f flash:vlan.dat
del /f sdflash:vlan.dat
del /f sdflash:pnp.dat
del /f flash:pnp.dat
del /f flash:*pnp*
del /f sdflash:*pnp*
conf t
no pnp profile pnp-zero-touch
exit
delete /for nvram:*.cer
delete /f flash:pnp-reset-config.cfg
delete /f sdflash:pnp-reset-config.cfg
conf t
crypto key zeroize
yes
no crypto pki certificate pool
yes
no crypto pki trustpoint pnplabel
yes
Vtp mode off
Vtp mode transparent
end
write erase
To check the status of the Policy Extended Node, go to Provision > Devices > Plug and Play
You should see the devices show up in the Plug and Play window and the devices will be in Provisioned state
Once the Policy Extended Nodes are provisioned in Plug and Play, they will start showing up in Fabric inventory and added to site in Managed State. Also, it will be added to Fabric Topology.
Authentication templates will have been provisioned onto the Policy Extended Node and all access ports will be provisioned with the default authentication profile – just as it were a Fabric Edge. Client devices can be connected to these access ports and authentication/authorization should succeed with ISE (ensure the ISE authorization rules and profiles are set just as you would with requests originating from a Fabric Edge i.e. assigning the VLAN and SGT).
Rather than relying on the default authentication profile you can go to Host Onboarding page, select the Policy Extended Node and configure the ports to be connected to AP or other IoT devices.
Use-Case Example
Host 2 is connected to a Fabric Edge (FE2), authenticated and authorized with ISE, placed into the correct VLAN/VN and assigned SGT4 Employees
The company policy is to block Employees from accessing PLC devices. A policy is added in Cisco DNA Center to block traffic from SGT Employees to SGT PLC
Cisco DNA Center pushes this policy to ISE.
A PLC device is connected to a Policy Extended Node (IE3400), authenticated and authorized with ISE, placed into the correct VLAN/VN and assigned SGT19 PLC.
As soon as the Policy Extended Node learns of this new SGT it needs to protect, it downloads the required policies from ISE:
SN-FOC2121Y0WB#sh cts role-based permissions
IPv4 Role-based permissions default:
        Permit IP-00
IPv4 Role-based permissions from group 4:Employees to group 19:PLC:
        Deny_IP_Log-00
RBACL Monitor All for Dynamic Policies : FALSE
RBACL Monitor All for Configured Policies : FALSE
If the Employee tries to access the PLC device, the source SGT (SGT4 Employees) is carried over VXLAN to FE1 and then carried in line from FE1 to the Policy Extended Node. The Policy Extended Node does a source SGT lookup, finds SGT4 Employees (received inline), then does a destination SGT lookup, finds SGT19 PLC (assigned by ISE). That flow is then enforced by the policy:
SN-FOC2121Y0WB#show cts role-based counters
Role-based IPv4 counters
From    To      SW-Denied  HW-Denied  SW-Permitt HW-Permitt SW-Monitor HW-Monitor
*       *       0          0          0          0          0          0
4       19      0          53         0          0          0          0
Verify CLI Configuration
Fabric Edge Device
Check the port channel and interface configuration (inline tagging enabled on the trunk):
FE2-9300-04#sh run int gig 1/0/2
interface GigabitEthernet1/0/2
 switchport mode trunk
 cts manual
  policy static sgt 8000 trusted
 channel-group 1 mode desirable
end
FE2-9300-04#sh run int port-channel 1
Building configuration...
Current configuration : 54 bytes
interface Port-channel1
end
ExtPool Management VLAN on FE
FE2-9300-04#sh run int Vlan1024
Current configuration : 292 bytes
interface Vlan1024
 description Configured from Cisco DNA-Center
 mac-address 0000.0c9f.f45f
 ip address 192.168.17.1 255.255.255.0
 ip helper-address 10.5.130.12
 no ip redirects
 ip route-cache same-interface
 no lisp mobility liveness test
 lisp mobility 192_168_17_0-INFRA_VN-IPV4
end
Host IP VLAN on FE
FE2-9300-04#sh run int Vlan1021
Current configuration : 590 bytes
interface Vlan1021
 mac-address 0000.0c9f.f45c
 vrf forwarding Campus_VN
 ip address 192.168.11.1 255.255.255.0
 no ip redirects
 lisp mobility 192_168_11_0-Campus_VN-IPV4
 lisp mobility 192_168_11_0-Campus_VN-IPV6
 ipv6 address 2003::1/96
 ipv6 enable
 ipv6 nd managed-config-flag
 ipv6 nd other-config-flag
 ipv6 nd router-preference High
 ipv6 dhcp relay destination ACE::1
 ipv6 dhcp relay source-interface Vlan1021
 ipv6 dhcp relay trust
end
Inline tagging authorized and trusted on Fabric Edge interface towards the Policy Extended Node:
FE2-9300-04#sh cts interface
Global Dot1x feature is Disabled
Interface GigabitEthernet1/0/2:
    CTS is enabled, mode:    MANUAL
    IFC state:               OPEN
    Interface Active for 00:57:45.274
    Authentication Status:   NOT APPLICABLE
        Peer identity:       "unknown"
        Peer's advertised capabilities: ""
    Authorization Status:    SUCCEEDED
        Peer SGT:            8000
        Peer SGT assignment: Trusted
    SAP Status:              NOT APPLICABLE
    Propagate SGT:           Enabled
    Cache Info:
        Expiration            : N/A
        Cache applied to link : NONE
    Statistics:
        authc success:              0
        authc reject:               0
        authc failure:              0
        authc no response:          0
        authc logoff:               0
        sap success:                0
        sap fail:                   0
        authz success:              0
        authz fail:                 0
        port auth fail:             0
    L3 IPM:   disabled.
Interface Port-channel1:
    CTS is disabled.
    L3 IPM:   disabled.
Uplink on the Policy Extended Node (with inline tagging enabled):
SN-FOC2121Y0WB#sh run int gig 1/10
interface GigabitEthernet1/10
 description PNP STARTUP VLAN
 cts manual
end
SN-FOC2121Y0WB#sh run int port-channel 1
end
CTS PAC and Environment-data downloaded from ISE on Policy Extended Node:
SN-FOC2121Y0WB#show cts pacs
AID: B34FA41307051BDEFC62F317FF5DBEC6
PAC-Info:
  PAC-type = Cisco Trustsec
  I-ID: FOC2121Y0WB
  A-ID-Info: Identity Services Engine
  Credential Lifetime: 15:45:46 UTC Wed Mar 18 2020
PAC-Opaque: 000200B80003000100040010B34FA41307051BDEFC62F317FF5DBEC60006009C000301002DD510E92D3FC4134FA57716B009AABF000000135DF41CD400093A807D3BE2BD82AE0D427EEB7FE5B2CA9465272F31DB47CC670BB06457B45502EDE1EF94B7F3F6720A833E4F26CB82053D11398168E701CA1C1B2B0D968207A800ADCCC0D3B8CB5DE2080166DAD9520403E2A3900CF8AA14C47FBFE923DA825675E99E89B09BD483DE92C2FD477D511049BDB2186CC264817D2EC64DFC2D
Refresh timer is set for 12w4d
SN-FOC2121Y0WB#show cts environment-data
CTS Environment Data
Current state = COMPLETE
Last status = Successful
Local Device SGT:
  SGT tag = 2-00:TrustSec_Devices
Server List Info:
Installed list: CTSServerList1-0001, 1 server(s):
 *Server: 10.1.200.127, port 1812, A-ID B34FA41307051BDEFC62F317FF5DBEC6
          Status = ALIVE
          auto-test = TRUE, keywrap-enable = FALSE, idle-time = 60 mins, deadtime = 20 secs
Security Group Name Table:
    0-00:Unknown
    3-00:Network_Services
    4-00:Employees
    5-00:Contractors
    6-00:Guests
    7-00:Production_Users
    8-00:Developers
    9-01:Auditors
    10-00:Point_of_Sale_Systems
    11-00:Production_Servers
    12-00:Development_Servers
    13-00:Test_Servers
    14-00:PCI_Servers
    15-00:BYOD
    16-00:Intranet
    17-00:Extranet
    18-00:Doctors
    255-00:Quarantined_Systems
Environment Data Lifetime = 86400 secs
Last update time = 15:45:45 UTC Thu Dec 19 2019
Env-data expires in   0:22:59:50 (dd:hr:mm:sec)
Env-data refreshes in 0:22:59:50 (dd:hr:mm:sec)
Cache data applied           = NONE
State Machine is running
Inline tagging authorized and trusted on Policy Extended Node interface towards the Fabric Edge:
SN-FOC2121Y0WB#sh cts interface
Interface GigabitEthernet1/10:
    IFC state:               OPEN
    Interface Active for 01:06:37.024
        Peer SGT:            8000
    Cache Info:
        Expiration            : N/A
    Statistics:
        authc success:              0
        authc reject:               0
        authc failure:              0
        authc logoff:               0
        sap success:                0
        sap fail:                   0
        authz success:              0
        authz fail:                 0
        port auth fail:             0
    L3 IPM:   disabled.
    CTS is disabled.
    L3 IPM:   disabled.
kis8fe_cisco
Frequent Visitor
Frequent Visitor
I have just tried bringing up an IE3400 connected to a pair of stacked 9300L following these instructions.
Sadly, the IE3400 came up as a regular Extended Node, not as Policy Extended Node. First of all, the license level needs to be Network-Advantage with DNA-Advantage enabled for the PEN role to even show up, without DNA-A the DNAC (mine currently running Ghost release) will show a warning.
After enabling DNA-A on my IE3400 and running a resync, the fabric role selection is showing the PEN role under the default EN role, but after moving the switch of PEN to on, I am not able to click on Add. Which means it is not possible to actually assign the PEN role.
HOLGER ALIX
Frequent Visitor
Frequent Visitor
same behavior as @kis8fe_cisco mentioned
DNAC Version 2.3.5 IE3400 17.9.4a , C9300 17.9.4a
All running Network/DNA Advantage (before adding to fabric)
Closed-Auth profiles missing, CTS Commands on Trunk missing (both sides)
Gui shows IE3400 as ext.-Node (PEN Switch automaticaly on)
Has anyone currently depolyed a PEN with DNAC Version 2.3.5 successful?
kis8fe_cisco
Frequent Visitor
Frequent Visitor
@HOLGER ALIX
I have done some more research and testing regarding this. I'm on 2.3.5.4 and have a few IE3400 running as EN and as PEN.
The issue I had was that I missed the little fine print in the IE3400 data sheet saying that PEN functionality is not supported with certain expansion modules. Namely the IEM-3300 modules. Here is the exact quote from the datasheet: "IE3300 expansion modules can also be plugged with IE3400 base switch. However, this combination prevents support for advanced security feature such as SGT/SGACL on the IE3400 base switch."
How I realized my mistake was that I tried running one of the steps in DNAC that are usually ran with edge nodes. I can't remember if it was provisioning or if I tried changing the fabric role. But the result was that the task failed because some cts related command was not found on my IE3400 with an IEM-3300-16P module. After some digging and asking Cisco I have figured out the limitation mentioned above.
The only strange thing is that you need to enable the right DNA license depending on whether you have or have not attached a 3300 expansion module. Without a module, you're fine with running dna-advantage and the switch will run as PEN. With a module, the license should be downgraded to dna-essentials, because otherwise the DNAC still tries to run it as a PEN which obviously will not work.
