Buenas tardes
Tengo la siguiente configuracion de mi ISP:
IP: 187.218.98.81
MS: 255.255.255.252
GW: 187.218.98.81
Vlan: 109
En este modem, solo se puede acceder mediante el puerto lan 1 configurando la vlan.
Tengo un router Cisco C891F al cual quiero configurar el puerto de Wan para que reciba el internet del modem, y luego  con nat , distribuir el internet en mi red interna. He configurado las interfaces y el nat pero no consigo hacer que se pueda acceder al internet desde los clientes. Esta es mi configuracion actual:
Current configuration : 2173 bytes
! Last configuration change at 17:33:07 UTC Sat Feb 1 2020 by cisco
version 15.3
interface BRI0
no ip address
encapsulation hdlc
shutdown
isdn termination multidrop
interface FastEthernet0
ip address 10.20.240.254 255.255.255.0
ip nat inside
ip virtual-reassembly in
duplex auto
speed auto
interface GigabitEthernet0
no ip address
interface GigabitEthernet1
no ip address
interface GigabitEthernet2
no ip address
interface GigabitEthernet3
no ip address
interface GigabitEthernet4
no ip address
interface GigabitEthernet5
no ip address
interface GigabitEthernet6
no ip address
interface GigabitEthernet7
no ip address
interface GigabitEthernet8
no ip address
ip nat outside
duplex auto
speed auto
interface GigabitEthernet8.109
encapsulation dot1Q 109
ip address 187.218.98.81 255.255.255.252
ip nat outside
interface Vlan1
no ip address
interface Async3
no ip address
encapsulation slip
ip forward-protocol nd
ip http server
no ip http secure-server
ip nat inside source list 100 interface GigabitEthernet8.113 overload
ip route 0.0.0.0 0.0.0.0 187.218.98.82
access-list 100 permit ip 10.20.240.0 0.0.0.255 any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
login local
no modem enable
line aux 0
line 3
modem InOut
speed 115200
flowcontrol hardware
line vty 0 4
login local
transport input all
line vty 5 15
login local
transport input all
scheduler allocate 20000 1000
end
de antemano gracias por la ayuda
Carlos Leiton1
Segun lo que veo, la interface que configuraste para este router es la interface GigabitEthernet8.109
Pero en el NAT configuraste otra diferente interface GigabitEthernet8.113
Cambiala a GigabitEthernet8.109 en en NAT y prueba otra vez.
