TCC_2
Community Member
Resolution
If runts and Cyclic Redundancy Check (CRC) errors are incrementing in the show interface command output, or Frame Check Sequence (FCS) errors and runts are incrementing in the show port command output, check the port speed and duplex settings.
Ensure that both devices are configured identically. Both sides should be   set to auto speed and auto duplex, or hard set to the same   speed and duplex settings.
These are explanations of CRC errors and runts:
  • CRC errors indicate that the cyclic redundancy checksum generated by the originating LAN device does not match the checksum calculated from the data received. On a LAN, this usually indicates noise or transmission problems on the LAN interface or the LAN bus itself. A high number of CRCs is usually     the result of collisions or a station transmitting bad data.
  • Runts are Ethernet packets that are less than 64 bytes and may be caused by excessive collisions.
On Cisco IOS -based switches, the interface configuration commands to   set the speed and duplex to auto are speed  auto and duplex  auto.
To hard set the speed and duplex settings, issue the duplex and speed commands   specifying the desired settings. For example, to set the interface to 100/full,   issue the speed   100 and duplex   full commands. Never mix a hard set and an auto command on the same   interface. For example, the speed   auto and duplex   full commands should never be issued on the same interface.
On Cisco set-based CatOS switches, there is only one command used to change   the port speed and duplex settings to auto. To change the port setting   back to  auto issue the set   port speed mod/port auto command. To hard set the speed   and duplex settings, issue the set   port speed mod/port speed and set   port duplex mod/port duplex commands. For example, to   set port 4/1 to 100/full, issue the set   port speed 4/1 100 and set   port duplex 4/1 full commands.
In CatOS there is not a command to change the duplex setting to auto, so.
If the speed and duplex settings are correct, yet the CRC or runt counters continue to increase, perform these steps:
  • Verify that the connected Network Interface Card (NIC) is good and has the latest drivers.
  • Verify that the cable connecting the devices is good, using a cable tester or by replacing it with a known good cable.
  • Verify that no interference is occurring on the line.
For more information, refer to Troubleshooting     Cisco Catalyst Switches to NIC Compatibility Issues.
For more information on port counters and possible solutions, paste your show command   output into the Output   Interpreter.
For additional information regarding Ethernet issues, refer to Troubleshooting     Ethernet.
Show interface
CRC
runts
Show interface counters
Collisions
