Mohamed Alhenawy
Today I'm going to write SD-WAN Overview & Advanced Deployment Lab Part ||
* check out SD-WAN Overview & Advanced Deployment Lab Part | through this link :
https://community.cisco.com/t5/networking-documents/sd-wan-overview-amp-advanced-deployment-lab-part-1/ta-p/4387959
Cisco Viptela SD-WAN on your platform:-
The Cisco Viptela  SD-WAN solution can deployed on a different platforms is called WAN Edge routers, which are available in different resources , Regardless of which deployment is chosen, all WAN Edge routers will be part of the SD-WAN overlay fabric and managed by vManage.
There are two types of platforms that can be deployed as part of Cisco viptela SD-WAN:
1. Hardware platforms
kisspng-data-center-services-colocation-centre-managed-ser-5b9fd8c0dda302.8043739815372023689078.jpg- Cisco vEdge (formerly Viptela vEdge ) Routers running Viptela OS
Integrated Services Router ISR 4000 and Aggregation Services Router ASR 1000 Series which 's  running IOS® XE SDWAN
Software.
●     Cisco ASR 1000 Series Aggregation Services Routers
●      Cisco 1000 Series ISRs
●      Cisco 4000 Series ISRs
●      Cisco 5400 ENCS
Existing routers must run 17.2.1 or a later release to interoperate with the Cisco IOS XE SD-WAN image. This is because of code changes introduced to support Bidirectional Forwarding Detection (BFD) tunnel building between a vEdge router and Cisco IOS XE based router.
NOTE : Check out this link : https://www.cisco.com/c/en/us/solutions/collateral/enterprise-networks/sd-wan/white_paper-c11-741071.html
2. Virtual platforms
• Cloud Services Router (CSR) 1000v running IOS XE SD-WAN Software
• vEdge Cloud Router running Viptela OS
NOTE:  Virtual platforms can also run on any  hypervisor such as KVM or VMware ESXi.
Feature TEMPLATES & Devices TEMPLATES :-
Feature templates are the building blocks for a device’s configuration. Feature templates has three categories <  BASIC INFORMATION , VPN ,OTHER TEMPLATES>  once you choose the device model device you will see all the available feature .9c1c4007b2da3330502be886db9ecac1.gif
features templates categories :
- BASIC INFORMATION templates :
AAA , Archive ,BFD ,NTP , OMP , Security , System ..
- VPN templates : VPN , VPN Interface Bridge , VPN Interface Ethernet , Management , VPN Interface GRE , VPN Interface IPsec, VPN Interface NATPool, etc ....
- OTHER TEMPLATES: Banner , BGP , Bridge , DHCP Server , IGMP , Logging , Multicast , OSPF, etc...
DEVICES Templet :
Device templates contain a devices complete configuration. You can create device templates by collecting all the  feature templates which 's you have done for specific device model, device templates allows customers to configure thousands of devices within few seconds.
NOTE : In case of configuration errors, the template configuration rolls back to its previous state.
LAB Configurations :
BFD Templet:
Configuration ----> Templates ----> features ----> Add Template ---->BFD
WAN Edge OMP
 Configuration ----> Templates ----> features ----> Add Template ---->OMP
WAN Edge System
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge System
NTP
 Configuration ----> Templates ----> features ----> Add Template ---->NTP
WAN Edge Security
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge Security
WAN Edge VPN 0
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge VPN
WAN Edge interface VPN 0
 Configuration ----> Templates ----> features ----> Add Template ----> WAN Edge interface VPN 0 - MPLS.
 Configuration ----> Templates ----> features ----> Add Template ----> WAN Edge interface VPN 0 - Biz-Internet
WAN Edge VPN 512
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge VPN 512
WAN Edge VPN 512
WAN Edge interface VPN 512
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge interface  VPN 512
Banner
 Configuration ----> Templates ----> features ----> Add Template ----> Banner
Branch-Internal-OSPF
 Configuration ----> Templates ----> features ----> Add Template ----> ospf
Branch-external-OSPF
WAN Edge  VPN Services 1
 Configuration ----> Templates ----> features ----> Add Template ---->  VPN1
WAN Edge interface VPN Services 1
 Configuration ----> Templates ----> features ----> Add Template ---->WAN Edge interface  VPN1
WAN Edge  VPN DC-Services 1
 Configuration ----> Templates ----> features ----> Add Template ---->  DC-VPN1
WAN Edge  interface VPN DC-Services 1
 Configuration ----> Templates ----> features ----> Add Template ---->  DC-interface VPN1
DC-internal-OSPF
DC-external-OSPF
DCS-VPN0
Configuration ----> Templates ----> features ----> Add Template ---->VPN
DCS- interface VPN0
Configuration ----> Templates ----> features ----> Add Template ---->wan edge interface
 We are going to make Device Templet for the V-smart  to move from CLI mode to Vmanage mode so we can push the route & policy to all overlay devices
VSmart template
Configuration ----> Templates ----> features ----> Add Template ---->system
NTP template
Configuration ----> Templates ----> features ----> Add Template ----> NTP
Banner template
Security template
Configuration ----> Templates ----> features ----> Add Template ----> security
VPN 0 template
Configuration ----> Templates ----> features ----> Add Template ----> vpn
Interface VPN 0 template
Configuration ----> Templates ----> features ----> Add Template ----> Vpn interface
Build the Device Templates for vEdges and V-samrt
Vsmart Device  template
Configuration ----> Templates ----> Device  ----> vsmart ----> template name
CLI
viptela-system:system
   device-model          vsmart
   host-name             v-Smart
   system-ip             10.10.10.102
   domain-id             1
   site-id               100
   admin-tech-on-failure
   sp-organization-name  "Cisco-ARCH"
   clock timezone America/Los_Angeles
   vbond 200.200.200.103 port 12346
   aaa
    auth-order local radius tacacs
    usergroup basic
     task system read write
     task interface read write
    usergroup netadmin
    usergroup operator
     task system read
     task interface read
     task policy read
     task routing read
     task security read
    user admin
     password $6$siwKBQ==$wT2lUa9BSreDPI6gB8sl4E6PAJoVXgMbgv/whJ8F1C6sWdRazdxorYYTLrL6syiG6qnLABTnrE96HJiKF6QRq1
   logging
    disk
     enable
   ntp
    server 200.200.200.100
     version 4
     prefer
    exit
  omp
   no shutdown
   graceful-restart
  banner
   login "Welcome To SD-Wan Fabric"
   motd  "Welcome to SD-Wan Fabric Please if you are not authorized to use the system , log out imedietaly"
  vpn 0
   name VPN-0
   interface eth0
    ip address 200.200.200.102/24
    tunnel-interface
     allow-service all
     allow-service dhcp
     allow-service dns
     allow-service icmp
     allow-service sshd
     allow-service netconf
     allow-service ntp
     allow-service stun
    no shutdown
   ip route 0.0.0.0/0 200.200.200.100
  vpn 512
   interface eth1
    description vSmart-interface-VPN512
    ip address 20.20.20.102/24
    no shutdown
   ip route 0.0.0.0/0 20.20.20.100
 DC vEdges :
CLI
   device-model            vedge-cloud
   host-name               vedge-DCS
   system-ip               10.10.10.211
   domain-id               1
   site-id                 1
   no route-consistency-check
   console-baud-rate       9600
   aaa
    usergroup basic
    usergroup netadmin
    usergroup operator
     task system read
     task interface read
     task policy read
     task routing read
     task security read
    user admin
   logging
    disk
     enable
   ntp
     version 4
     prefer
    exit
  bfd app-route multiplier 6
  bfd app-route poll-interval 600000
  omp
   no shutdown
   graceful-restart
   advertise connected
   advertise static
  security
   ipsec
    authentication-type sha1-hmac ah-sha1-hmac
  banner
  vpn 0
   name DCS-VPN0
   router
    ospf
     timers spf 200 1000 10000
     redistribute static
     redistribute connected
     area 0
      interface ge0/2
      exit
     exit
   interface ge0/2
    description DCS-Interface-VPN0
    ip address 211.211.211.2/24
    tunnel-interface
     encapsulation ipsec
     allow-service all
     allow-service bgp
     allow-service dhcp
     allow-service dns
     allow-service icmp
     allow-service sshd
     allow-service ntp
     allow-service ospf
     allow-service stun
     allow-service https
    no shutdown
   ip route 0.0.0.0/0 211.211.211.1
  vpn 1
   name DCS-VPN1
   router
    ospf
     redistribute static
     redistribute omp
     area 0
      interface ge0/3
      exit
     exit
   interface ge0/3
    description DCS-Interface-VPN1
    ip address 80.80.80.1/24
    no shutdown
   ip route 0.0.0.0/0 80.80.80.2
   omp
    advertise bgp
    advertise ospf external
    advertise connected
    advertise static
  vpn 512
   interface eth1
    ip dhcp-client
    no shutdown
Stay tuned for part |||  , Press Star if it's helpful for your knowledge !
***** I hope that has been informative for you and thank you *****
Mohamed Alhenawy
CCIE#60453
borrexlinux
Thanks Mohamed.
Can you share files eve-ng please?
Mohamed Alhenawy
Hello @borrexlinux
Yes sure , check you DM
hadeekeeth
Hi Mohamed.
Great Work ! If you don't mind please share the eve-ng files for LAB 1 & 2. Thanks!
Mohamed Alhenawy
Hi @hadeekeeth
Thanks for your kind keywords , no worries  Please share your private mail through DM .
JoshB1
Great Post, I am working my way through lab 1 and 2.
Took me a min to figure out you we using static routing for the "internet"
Mohamed Alhenawy
Hi Joshb1,
Thanks for your kind keywords , as I understand form you question , you asking about the static route for the internet ?
Here you go , For the know network ( Viptela Controllers ) using static route to route all traffic to DC edge  , for unknown network (0.0.0.0) route all the traffic to external interface.
Hello Mohamed very informative lab and nots if possible can I get these Sdwan file notes  on email please so I do study please
pawansharma0761@gmail.com
Mohamed Alhenawy
marina.bunin
Hi.
I am working on a test environment, only with virtual devices, however when I try to populate the WAN edge device list from CSV file it says that "Error: Virtual Platform is not allowed in CSV Upload."
Is there any other way to do IT? I am planning to have a fully isolated environment in my lab.
Mohamed Alhenawy
Hi @marina.bunin
Yes we can solve it check out you private message
soufiansaheb
hello @Mohamed Alhenawy  great lab, with clear explanation  please can you share the lab file
Mohamed Alhenawy
Helllo @soufiansaheb
thanks for your feedback, yes sure please share your mail through PM
