ekhabaro
Introduction
This article describes problem that will arise when asymmetric paths are used for traffic forwarding in SD-WAN fabric.
Problem
User reported that SSH connections can't be established to host2 (hostname - edgeclien2) from host1 (hostname - edgeclien1), but at the same time SSH works fine in reverse direction.
[root@edgeclient2 user]# ssh user@192.168.40.21
user@192.168.40.21's password:
Last login: Sun Feb 10 13:26:32 2019 from 192.168.60.20
[user@edgeclient1 ~]$
[root@edgeclient1 user]# ssh user@192.168.60.20
<nothing happening after that>
or
[user@edgeclient1 ~]$ ssh user@192.168.60.20
ssh_exchange_identification: Connection closed by remote host
Both edgeclient1 and edgeclient2 SSH daemons and clients have known good configurations and connections can be established from local LAN segment successfully:
vedge4# request execute vpn 40 ssh user@192.168.60.20
user@192.168.60.20's password:
Last login: Sun Feb 10 13:28:23 2019 from 192.168.60.7
[user@edgeclient2 ~]$
All other TCP applications have similar problems.
Topology Diagram
Diagnostic
Following ACLs were configured and applied in corresponding directions on service-side interfaces of vEdge1 and vEdge3:
policy
 access-list SSH_IN
  sequence 10
   match
    source-ip      192.168.40.21/32
    destination-ip 192.168.60.20/32
   action accept
    count SSH_IN
  default-action accept
 access-list SSH_OUT
  sequence 10
   match
    source-ip      192.168.60.20/32
    destination-ip 192.168.40.21/32
   action accept
    count SSH_OUT
Mirrored ACL was applied on vEdge4:
policy
 access-list SSH_IN
  sequence 10
   match
   action accept
    count SSH_IN
 access-list SSH_OUT
  sequence 10
   match
   action accept
    count SSH_OUT
Also app-visibility was enabled on all vEdge routers and flows were checked during SSH connection establishment phase:
vedge1# show app cflowd flows | tab ; show policy access-list-counters
                                                             TCP        TIME    EGRESS  INGRESS
                                   SRC    DEST        IP     CNTRL  ICMP                   TOTAL  TOTAL  MIN  MAX                            TO      INTF    INTF
VPN  SRC IP         DEST IP        PORT   PORT  DSCP  PROTO  BITS   OPCODE  NHOP IP        PKTS   BYTES  LEN  LEN  START TIME                EXPIRE  NAME    NAME
40   192.168.40.21  192.168.60.20  47866  22    0     6      24     0       192.168.109.7  3      227    66   87   Sun Feb 17 14:13:25 2019  34      ge0/0   ge0/1
         COUNTER
NAME     NAME     PACKETS  BYTES
SSH_IN   SSH_IN   3        227
SSH_OUT  SSH_OUT  2        140
vedge3# show app cflowd flows | tab ; show policy access-list-counters
40   192.168.60.20  192.168.40.21  22    47866  0     6      18     0       192.168.40.21  8      480    60   60   Sun Feb 17 14:14:08 2019  51      ge0/1   ge0/0
         COUNTER
SSH_IN   SSH_IN   0        0
SSH_OUT  SSH_OUT  7        420
vedge4# show app cflowd flows | tab ; show policy access-list-counters
40   192.168.40.21  192.168.60.20  47866  22     0     6      2      0       192.168.60.20  4      240    60   60   Sun Feb 17 14:17:44 2019  37      ge0/2   ge0/0
40   192.168.60.20  192.168.40.21  22     47866  0     6      18     0       192.168.110.6  8      592    74   74   Sun Feb 17 14:17:44 2019  49      ge0/0   ge0/2
         COUNTER
SSH_IN   SSH_IN   8        592
SSH_OUT  SSH_OUT  4        240
As we can see from the outputs above, inbound and outbound flows are asymmetric. edgeclient1 (192.168.40.21) is trying to establish SSH session with edgeclient2 (192.168.60.20) and incoming traffic comes via vEdge1 and return traffic returns via vEdge3. From the ACL counters we can see also that number of incoming and outgoing packets on vEdge4 doesn't match with with sum in corresponding directions on vEdge1 and vEdge3. At the same time, there is no packet loss when testing with ping:
[root@edgeclient1 user]# ping -f 192.168.60.20 -c 10000
PING 192.168.60.20 (192.168.60.20) 56(84) bytes of data.
--- 192.168.60.20 ping statistics ---
10000 packets transmitted, 10000 received, 0% packet loss, time 3076ms
rtt min/avg/max/mdev = 0.128/0.291/6.607/0.623 ms, ipg/ewma 0.307/0.170 ms
[root@edgeclient2 user]# ping -f 192.168.40.21 -c 10000
PING 192.168.40.21 (192.168.40.21) 56(84) bytes of data.
--- 192.168.40.21 ping statistics ---
10000 packets transmitted, 10000 received, 0% packet loss, time 3402ms
rtt min/avg/max/mdev = 0.212/0.318/2.766/0.136 ms, ipg/ewma 0.340/0.327 ms
Also please recap that SSH works fine in reverse direction and user can copy files over scp/sftp as well without any issues.
Solution
Some DPI or data policy were suspected initially, but none of them were activated:
vedge3# show policy from-vsmart
% No entries found.
vedge1# show policy from-vsmart
% No entries found.
But eventually it was found that TCP optimization was enabled:
vedge1# show app tcp-opt active-flows
        EGRESS  INGRESS
                                   SRC    DEST                            INTF    INTF     TX     RX                  UNOPT   PROXY
VPN  SRC IP         DEST IP        PORT   PORT  START TIME                NAME    NAME     BYTES  BYTES  TCP STATE    REASON  IDENTITY
40   192.168.40.21  192.168.60.20  47868  22    Sun Feb 17 14:18:13 2019  ge0_0   ge0_1    314    0      In-progress  -       Client-Proxy
vedge1# show app tcp-opt expired-flows
                                                  SRC    DEST                                                       TX     RX                UNOPT   PROXY
TIMESTAMP      VPN  SRC IP         DEST IP        PORT   PORT   START TIME                END TIME                  BYTES  BYTES  TCP STATE  REASON  IDENTITY      DELETE REASON
1549819969608  40   192.168.40.21  192.168.60.7   22     56612  Sun Feb 10 18:32:49 2019  Sun Feb 10 18:36:03 2019  5649   4405   Optimized  -       Server-Proxy  CLOSED
1549820055487  40   192.168.40.21  192.168.60.7   22     56613  Sun Feb 10 18:34:15 2019  Sun Feb 10 19:07:46 2019  5719   4669   Optimized  -       Server-Proxy  CLOSED
1550408210511  40   192.168.40.21  192.168.60.20  47862  22     Sun Feb 17 13:56:50 2019  Sun Feb 17 13:56:58 2019  401    0      Optimized  -       Client-Proxy  STATE-TIMEOUT
1550408981634  40   192.168.40.21  192.168.60.20  47864  22     Sun Feb 17 14:09:41 2019  Sun Feb 17 14:09:49 2019  401    0      Optimized  -       Client-Proxy  STATE-TIMEOUT
1550409205399  40   192.168.40.21  192.168.60.20  47866  22     Sun Feb 17 14:13:25 2019  Sun Feb 17 14:13:33 2019  227    0      Optimized  -       Client-Proxy  STATE-TIMEOUT
1550409493042  40   192.168.40.21  192.168.60.20  47868  22     Sun Feb 17 14:18:13 2019  Sun Feb 17 14:18:21 2019  401    0      Optimized  -       Client-Proxy  STATE-TIMEOUT
Besides that, in debugs ftm tcpopt CONN_TEARDOWN message can be seen.
vedge1# show log /var/log/tmplog/vdebug tail "-f"
local7.debug: Feb 17 13:56:50 vedge1 FTMD[662]: ftm_tcpopt_flow_add[268]: Created new tcpflow :- vrid-3 192.168.40.21/47862 192.168.60.20/22
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_send_conn_tear_down[388]: Trying to pack and send the following message to TCPD
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_send_conn_tear_down[408]: Sending following CONN_TD msg
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_send_conn_tear_down[413]: 192.168.40.21:47862->192.168.60.20:22; vpn:40; syn_seq_num:4172167164; identity:0; cport_prime:0
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_msgq_tx[354]: Transfering size = 66 bytes data
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_send_conn_tear_down[416]: Successfully sent conn_td msg to TCPD
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpopt_propagate_tear_down[1038]: Sent CONN_TEARDOWN msg to tcpd for existing tcpflow :- vrid-3 192.168.40.21/47862 192.168.60.20/22 ; identity:CLIENT_SIDE_PROXY . Send Successful !
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpopt_append_expired_err_flow_tbl[958]: Appending flow vrid-3 192.168.40.21/47862 192.168.60.20/22  to the expired flow table at Sun Feb 17 13:56:58 2019
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpopt_append_expired_err_flow_tbl[980]: Appending flow vrid-3 192.168.40.21/47862 192.168.60.20/22  to the error flow table at Sun Feb 17 13:56:58 2019
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpopt_flow_delete[293]: Removing tcpflow :- vrid-3 192.168.40.21/47862 192.168.60.20/22
local7.debug: Feb 17 13:56:58 vedge1 TCPD[670]: handle_upstream_connect[538]: Error - BP NULL
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_msg_decode[254]: FTM-TCPD: Received FTM_TCPD__PB_FTM_TCPD_MSG__E_MSG_TYPE__CONN_CLOSED msg
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_handle_conn_closed[139]: FTM-TCPD: Received CONN_CLOSED for following C->S
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_handle_conn_closed[150]: 192.168.40.21:47862->192.168.60.20:22; vpn:40; syn_seq_num:4172167164; identity:0; cport_prime:47862; bind_port:0
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_handle_conn_closed[184]: FTM-TCPD: Could not find entry in FT for following flow
local7.debug: Feb 17 13:56:58 vedge1 FTMD[662]: ftm_tcpd_handle_conn_closed[185]: vrid-3 192.168.40.21/47862 192.168.60.20/22
And here you can see an example when TCP optimization works properly (CONN_EST message can be seen):
vedge3# show log /var/log/tmplog/vdebug tail "-f -n 0"
local7.debug: Feb 17 15:41:13 vedge3 FTMD[657]: ftm_tcpd_msg_decode[254]: FTM-TCPD: Received FTM_TCPD__PB_FTM_TCPD_MSG__E_MSG_TYPE__CONN_CLOSED msg
local7.debug: Feb 17 15:41:13 vedge3 FTMD[657]: ftm_tcpd_handle_conn_closed[139]: FTM-TCPD: Received CONN_CLOSED for following C->S
local7.debug: Feb 17 15:41:13 vedge3 FTMD[657]: ftm_tcpd_handle_conn_closed[150]: 192.168.40.21:47876->192.168.60.20:22; vpn:40; syn_seq_num:2779178897; identity:0; cport_prime:47876; bind_port:0
local7.debug: Feb 17 15:41:15 vedge3 FTMD[657]: ftm_tcpd_msg_decode[258]: FTM-TCPD: Received FTM_TCPD__PB_FTM_TCPD_MSG__E_MSG_TYPE__CONN_EST msg
local7.debug: Feb 17 15:41:15 vedge3 FTMD[657]: ftm_tcpd_handle_conn_est[202]: FTM-TCPD: Received CONN_EST for following C->S
local7.debug: Feb 17 15:41:15 vedge3 FTMD[657]: ftm_tcpd_handle_conn_est[213]: 192.168.40.21:47878->192.168.60.20:22; vpn:40; syn_seq_num:2690847868; identity:0; cport_prime:47878; bind_port:0
local7.debug: Feb 17 15:41:15 vedge3 FTMD[657]: ftm_tcpopt_flow_add[268]: Created new tcpflow :- vrid-3 192.168.40.21/47878 192.168.60.20/22
Conclusion
TCP optimization as any other DPI feature requires flows to be symmetric, hence to resolve this problem either TCP optimization should be disabled (no vpn 40 tcp-optimization) or data policy should be created to force TCP flows take same path in both directions. You can find more information about this in SD-WAN Design Guide section "Traffic symmetry for DPI", page 23.
