ashirkar
Level 7
Level 7
Introduction:
This document describes the difference between implementation of static routes with next hop as an exit interface or an IP address.
!-- Pointing to next hop address
ip route 0.0.0.0 0.0.0.0 10.1.1.2
!-- Pointing to the interface
ip route 0.0.0.0 0.0.0.0 fa0/0
Basic Overview:
For forwarding packet to the destination, the router must determine the exit interface and rewrite the L2 frame before putting the packet on the wire. In order for a router to write the L2 frame it must resolve the IP address to its corresponding L2 address and reconstruct the frame before sending to the next hop. The function of address resolution can be done dynamically using protocols like ARP in Ethernet or Statically/Dynamically learned DLCI in frame-relay.
There are two points need to be understand, when you configure static route on router.
1) If you configured static route pointed to next hop IP address, for every destination forwarding router requires only L2 address of next hop IP address to rewrite the L2 frame.
Example: ip route 2.2.2.0 255.255.255.0 10.1.1.2
For routing packet to destination address 2.2.2.2, router requires L2 mac address of 10.1.1.2.
2) If you configured static route point to outgoing interface, forwarding router assume destination address is directly connected to that interface and router will try to find the L2 address of the destination by sending ARP request out of the interface to the destination address in case of Ethernet or looking for a static/dynamic map entry in the mapping table in case of frame-relay.
Example: ip route 2.2.2.0 255.255.255.0 fa0/0
For routing packet to the destination address 2.2.2.2, router assumes host 2.2.2.2 is directly connected to the interface fa0/0 and it requires L2 mac address for 2.2.2.2.
In general, interfaces can be point to point or multi-point. The above mentioned conditions work differently in scenarios of  Point to point and multipoint interface.
In point to point interface, by definition two devices are directly connected, so in case if  you configure static route pointing to outgoing interface or next hop IP address does not make a difference, router uses L2 address of next hop IP address of interface for routing packet to every destination address.
In multipoint interface, by definition interface can have multiple devices connected to it. So as mention above in point number two, if you configure static route point to next-hop, router need L3 to L2 resolution for each destination prefixes. Ethernet is an example of multi-point interfaces whereas Frame-relay and ATM can be multi-point interface or point to point depending on the configuration.
Configuration overview:
The topology and initial configurations are shown below:
Topology diagram:
Initial configuration:
R1R2R3
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.1.1.2 255.255.255.252
duplex auto
speed auto
interface FastEthernet0/1
ip address 20.1.1.1 255.255.255.0
duplex auto
speed auto
ip route 2.2.2.2 255.255.255.255 10.1.1.1
ip route 3.3.3.3 255.255.255.255 20.1.1.2
interface Loopback0
ip address 2.2.2.2 255.255.255.255
ip address 10.1.1.1 255.255.255.252
duplex auto
speed auto
interface Loopback0
ip address 3.3.3.3 255.255.255.255
ip address 20.1.1.2 255.255.255.252
duplex auto
speed auto
ip route 0.0.0.0  0.0.0.0 20.1.1.1
Case1: Configured static route on R2 point to the next hop address of neighboring router R1. As discussed above, for forwarding every packet to destination prefix R2 will use destination mac address of R1 in L2 frame.
Verifying connectivity from R2 to R1 and R3 loopback addresses:
R2#ping 1.1.1.1 so 2.2.2.2
Sending 5, 100-byte ICMP Echos to 1.1.1.1, timeout is 2 seconds:
Packet sent with a source address of 2.2.2.2
Success rate is 100 percent (5/5), round-trip min/avg/max = 20/28/40 ms
R2#ping 3.3.3.3 so 2.2.2.2
Sending 5, 100-byte ICMP Echos to 3.3.3.3, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 16/35/60 ms
R2#sh ip arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.1.1.1                -   c000.3148.0000  ARPA   FastEthernet0/0
Internet  10.1.1.2                0   c001.3148.0000  ARPA   FastEthernet0/0
Case2: Configured a static route on R2 point to the outgoing interface. As  discussed above, for forwarding every packet R2 assume destination  address is directly connected to that interface and will try to find the  L2 mac address of the every destination by sending ARP request out of  the interface to the destination address.
R2(config)#no ip route 0.0.0.0 0.0.0.0 10.1.1.2
R2(config)#ip route 0.0.0.0 0.0.0.0 fa0/0
Connectivity  verification from R2 to R1 and R3 loopback addresses. Also IP packet  debug turned on R2 to get closer packet level view.
R2#debug ip packet detail
IP packet debugging is on (detailed)
IP: tableid=0, s=2.2.2.2 (local), d=3.3.3.3 (FastEthernet0/0), routed via RIB
IP: s=2.2.2.2 (local), d=3.3.3.3 (FastEthernet0/0), len 100, sending
    ICMP type=8, code=0
IP: s=2.2.2.2 (local), d=3.3.3.3 (FastEthernet0/0), len 100, encapsulation failed
    ICMP type=8, code=0.
    ICMP type=8, code=0
R2#sh ip arp
Internet  1.1.1.1                 0   Incomplete      ARPA
Internet  3.3.3.3                 0   Incomplete      ARPA
Internet  10.1.1.2               16   c001.3148.0000  ARPA   FastEthernet0/0
Internet  10.1.1.5                -   c000.3148.0001  ARPA   FastEthernet0/1
As  1.1.1.1 and 3.3.3.3 prefixes are not directly connected to fa0/0, R2 is  not getting L2 mac address of these prefixes hence ARP table entry is  showing incomplete and there is L2 encapsulation failure on R2 is  dropping packets for this destination.
There are two tricky works around are available but these are not solutions just explained for user’s information.
1) Enabling proxy ARP on next hop router:
If  you enable proxy ARP on router, Whenever router get address resolution  request it send the proxy ARP of its own interface address to the  requested router, Only if the prefixes are present in its routing table.
In  this example R1 sends proxy ARP i.e. L2 mac address of 10.1.1.2 to R2  for prefixes 3.3.3.3 and 2.2.2.2, as both are in its routing table. By  default proxy ARP is enable on the most of the routers.
R1#conf t
Enter configuration commands, one per line.  End with CNTL/Z.
R1(config)#int fa0/0
R1(config-if)#ip proxy-arp
R1(config-if)#do sh ip int fa0/0 | in Proxy
             Proxy ARP is enabled
             Local Proxy ARP is enabled
Verifying connectivity from R2 to R1 and R3 loopback address:
Take  closer look at Arp table of R2, it is showing that same mac address  present for 3.3.3.3 and 1.1.1.1 prefixes in address resolution table  because R1 is sending proxy ARP of its own interface address.
R2#sh ip arp
Internet  1.1.1.1                 0   c001.3148.0000  ARPA   FastEthernet0/0
Internet  3.3.3.3                 0   c001.3148.0000  ARPA   FastEthernet0/0
Internet  10.1.1.2               40   c001.3148.0000  ARPA   FastEthernet0/0
Hence  this could result in a large amount of broadcast traffic and a large no  of ARP cache on R2, especially if the static route was a default route  used for internet traffic.
2) Adding manual ARP entries in ARP table:
You can also add manual ARP entries for destination prefixes to build L2 frame as shown below:
R2(config)#arp 1.1.1.1 c001.3148.0000 arpa
R2(config)#arp 3.3.3.3 c001.3148.0000 arpa
R2#sh ip arp
Internet  1.1.1.1                 -   c001.3148.0000  ARPA
Internet  3.3.3.3                 -   c001.3148.0000  ARPA
Internet  10.1.1.2                4   c001.3148.0000  ARPA   FastEthernet0/0
To build L2 frame for each destination prefixes you will need to add manual entries in address resolution table.
Conclusion:
->For point to point interfaces,  you can use static routes that point to the interface or to the next  hop address. There is only one possible next hop and its L2 address will  be used to build L2 frame.
->For multipoint/Broadcast interfaces,  it is more suitable to use static routes that point to a next hop  address to avoid the need for resolving every destination address to its  L2 address. As you have seen above it is still possible to use static  routes pointing to the interface but not a scalable solution.
Base Initial configuration:
Richard Burts
Perhaps you can post a simple diagram showing the topology of the network, especially where is the device on which you are configuring the static route, and on the device with HSRP where are its connections to the LAN and where are its connections to the WAN?
Rick
martin.szarka
You can use HSRP at any level of the network - if the conditions of the network allows you to do so and I would say that is recommended to use HSRP whenever it's possible.
If the redundancy is not designed in the same way from WAN side, then you have inconsitent routing.
Example:
HSRP is configured on R1 and R2, where the R1 is active while R2 is stanby.
When the R1 fail - R2 is taking over on LAN part, but the response from WAN will be still pointing to R1.
You should consider also indirect failure - because if you have link UP towards modem but the modem cannot reach the network your simple setings will not triger a change. You can use tracking object for that - I'm sure you will find more information in some HSRP topic.
BRG.
M.S.
blue phoenix
Hi thanks for answering,
here is the diagram...
blue phoenix
A static route to a next hop using exit interface and next hop IP solves a secure device not allowing proxy-arp.  We have proven that when we try to troubleshoot how come the loopback is not reachable but the point to point interfaces are on a 1921 router.
Tanasis Yankov
Its not wise at all , its grows your arp table to unmanaged size , but indeed this is enable by default so this is working question is  there are  some versions of ios that doesn't support proxy-arp by default ?
cvonhausen1
Hi, Can both routes be on the same running config:
is there any issues with that setting?
Thanks!
