SunilKhanna
Introduction
Loop prevention in BGP is done by verifying the AS number in the AS Path. If the receiving router sees its own AS number in the AS Path of the received BGP packet, the packet is dropped. The receiving Router assumes that the packet was originated from its own AS and has reached the same place from where it originated initially.
The feature could be a disaster if customers are using same AS number along the various sites and disallows customer sites having identical AS numbers to be linked by another AS number. In such a scenario, routing updates from one site will be dropped when the other site receives them.
To override this feature, AS-Override function causes to replace the AS number of originating router with the AS number of the sending BGP router. The command is neighbor ip-address as-override and can only be executed under the VPNv4 address-family.
Here are the steps to illustrate the As-Override process
  • Router TAURUS_Site-A advertises route 10.3.3.3 with AS100.
  • Router PE-1 propagates this as an internal route to PE2 as AS100.
  • PE2 prepends 10.3.3.3 with AS 121 and replaces 100 in the AS-Path to 121 and propagates the prefix.
  • Router TAURUS_Site-B accepts 10.3.3.3 update.
Prerequisite
  • Understanding of MPLS Technology
  • Understanding of MBGP
  • Understanding of OSPF routing protocol
Topology Diagram
Background
In this Topology, router PE-1 and PE-2 forms the Service Provider MPLS Cloud. The two routers are connected via fast Ethernet interface 0/0 and are running OSPF (Area 0) routing protocol. MPLS is configured on physical links (Fast Ethernet 0/0) of the SP network. Tagging is done via LDP and the labels are assigned in the range 100-199 on PE1 and 200-299 on PE2.
TAURUS and CINDY are the two customers with multiple sites (Site-A and Site-B). Customer TAURUS is operating under AS 100 and customer CINDY is operating under AS 200.
VPNv4 neighbor relationship is configured between (vrf TAURUS and vrf CINDY)
  • PE-1 & TAURUS_Site-A
  • PE-1 & CINDY_Site-A
  • PE-2 & TAURUS_Site-B
  • PE-2 & CINDY_Site-A
Routes from each site are advertised to PE routers within EBGP session. These routes are further propagated to next PE routers which are then forwarded to respective Customer-Site.
Note: All configurations are tested on Cisco 3700 series router with IOS 12.4.
Configuration
1. PE Configuration
PE-1PE-2
hostname PE-1
ip cef
ip vrf CINDY
rd 1:200
route-target export 1:200
route-target import 1:200
ip vrf TAURUS
rd 1:100
route-target export 1:100
route-target import 1:100
no ip domain lookup
mpls label range 100 199
mpls label protocol ldp
interface Loopback0
ip address 1.1.1.1 255.255.255.255
interface FastEthernet0/0
ip address 10.12.12.1 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
ip vrf forwarding TAURUS
ip address 192.13.13.1 255.255.255.252
clock rate 2000000
interface Serial0/1
ip vrf forwarding CINDY
ip address 192.14.14.1 255.255.255.252
clock rate 2000000
router ospf 10
router-id 1.1.1.1
log-adjacency-changes
network 1.1.1.1 0.0.0.0 area 0
network 10.12.12.1 0.0.0.0 area 0
router bgp 121
no synchronization
bgp log-neighbor-changes
network 11.11.11.11 mask 255.255.255.255
neighbor 2.2.2.2 remote-as 121
neighbor 2.2.2.2 update-source Loopback0
neighbor 2.2.2.2 next-hop-self
no auto-summary
address-family vpnv4
  neighbor 2.2.2.2 activate
  neighbor 2.2.2.2 send-community both
exit-address-family
address-family ipv4 vrf TAURUS
  redistribute connected
  neighbor 192.13.13.2 remote-as 100
  neighbor 192.13.13.2 activate
  neighbor 192.13.13.2 as-override
  no synchronization
exit-address-family
address-family ipv4 vrf CINDY
  neighbor 192.14.14.2 remote-as 200
  neighbor 192.14.14.2 activate
  neighbor 192.14.14.2 as-override
  no synchronization
exit-address-family
mpls ldp router-id Loopback0
exit
hostname PE-2
ip cef
ip vrf CINDY
rd 1:200
ip vrf TAURUS
rd 1:100
no ip domain lookup
mpls label range 200 299
interface Loopback0
ip address 2.2.2.2 255.255.255.255
interface Loopback1
ip address 22.22.22.22 255.255.255.255
ip address 10.12.12.2 255.255.255.0
duplex auto
speed auto
mpls ip
interface Serial0/0
ip address 192.23.23.1 255.255.255.252
clock rate 2000000
interface Serial0/1
ip address 192.26.26.1 255.255.255.252
clock rate 2000000
router ospf 10
router-id 2.2.2.2
network 2.2.2.2 0.0.0.0 area 0
network 10.12.12.2 0.0.0.0 area 0
router bgp 121
no synchronization
network 22.22.22.22 mask 255.255.255.255
neighbor 1.1.1.1 remote-as 121
neighbor 1.1.1.1 update-source Loopback0
neighbor 1.1.1.1 next-hop-self
no auto-summary
  neighbor 1.1.1.1 activate
  neighbor 1.1.1.1 send-community both
exit-address-family
  neighbor 192.23.23.2 remote-as 100
  neighbor 192.23.23.2 activate
  neighbor 192.23.23.2 as-override
  no synchronization
exit-address-family
  neighbor 192.26.26.2 remote-as 200
  neighbor 192.26.26.2 activate
  neighbor 192.26.26.2 as-override
  no synchronization
exit-address-family
exit
2. CE Configuration
TAURUS_Site-ACINDY_Site-ATAURUS_Site-BCINDY_Site-B
hostname TAURUS-Site_A
ip cef
no ip domain lookup
interface Loopback0
ip address 10.3.3.3 255.255.255.255
interface Serial0/0
ip address 192.13.13.2 255.255.255.252
clock rate 2000000
router bgp 100
no synchronization
network 10.3.3.3 mask 255.255.255.255
neighbor 192.13.13.1 remote-as 121
no auto-summary
exit
hostname CINDY-SITE_A
ip cef
no ip domain lookup
interface Loopback0
ip address 10.4.4.4 255.255.255.255
interface Serial0/0
ip address 192.14.14.2 255.255.255.252
clock rate 2000000
router bgp 200
no synchronization
network 10.4.4.4 mask 255.255.255.255
neighbor 192.14.14.1 remote-as 121
no auto-summary
exit
hostname TAURUS-Site_B
ip cef
no ip domain lookup
interface Loopback0
ip address 10.5.5.5 255.255.255.255
interface Serial0/0
ip address 192.23.23.2 255.255.255.252
clock rate 2000000
router bgp 100
no synchronization
network 10.5.5.5 mask 255.255.255.255
neighbor 192.23.23.1 remote-as 121
no auto-summary
exit
hostname CINDY-SITE_B
ip cef
no ip domain lookup
interface Loopback0
ip address 10.6.6.6 255.255.255.255
interface Serial0/0
ip address 192.26.26.2 255.255.255.252
clock rate 2000000
router bgp 200
no synchronization
network 10.6.6.6 mask 255.255.255.255
neighbor 192.26.26.1 remote-as 121
no auto-summary
exit
Verification
PE-1#show ip bgp vpnv4 all summary
< output truncated >
Neighbor        V    AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
2.2.2.2           4    121     115     116            15       0    0      01:09:16        4
192.13.13.2    4    100      70      74             15       0     0      00:46:42        1
192.14.14.2    4    200      41      44             15       0     0      00:36:14        1
PE-2#show ip bgp vpnv4 all summary
1.1.1.1            4   121     119     118             15       0    0      01:11:22        4
192.23.23.2     4   100      53      56               15       0    0      00:48:07        1
192.26.26.2     4   200      41      44               15       0    0      00:36:46        1
PE-1#sh ip route vrf  TAURUS bgp
     192.23.23.0/30 is subnetted, 1 subnets
B       192.23.23.0 [200/0] via 2.2.2.2, 00:25:32
     10.0.0.0/32 is subnetted, 2 subnets
B       10.3.3.3 [20/0] via 192.13.13.2, 00:35:30
B       10.5.5.5 [200/0] via 2.2.2.2, 00:33:03
PE-1#show ip route vrf CINDY bgp
     192.26.26.0/30 is subnetted, 1 subnets
B       192.26.26.0 [200/0] via 2.2.2.2, 00:27:05
B       10.6.6.6 [200/0] via 2.2.2.2, 00:32:36
B       10.4.4.4 [20/0] via 192.14.14.2, 00:34:51
BGP table version is 15, local router ID is 11.11.11.11
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
              r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
    Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 1:100 (default for vrf TAURUS)
*> 10.3.3.3/32      192.13.13.2                 0                   0 100 i
*>i10.5.5.5/32      2.2.2.2                        0     100         0 100 i
*> 192.13.13.0/30   0.0.0.0                      0              32768 ?
*>i192.23.23.0/30   2.2.2.2                      0      100          0 ?
Route Distinguisher: 1:200 (default for vrf CINDY)
*> 10.4.4.4/32      192.14.14.2                 0                    0 200 i
*>i10.6.6.6/32      2.2.2.2                        0    100           0 200 i
*> 192.14.14.0/30   0.0.0.0                      0               32768 ?
*>i192.26.26.0/30   2.2.2.2                      0     100            0 ?
TAURUS-Site_A#ping 10.5.5.5
Sending 5, 100-byte ICMP Echos to 10.5.5.5, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 456/696/972 ms
The prefix 10.5.5.5 (from Router TAURUS-Site_B) is receieved and pinged successfully from Router TAURUS-Site_A.
References
Cisco IOS IP and IP Routing Command Reference
Configuring Basic MPLS VPN
Cisco IOS Multiprotocol Label Switching Configuration Guide
Cisco MPLS Support Page
Cisco BGP Support Page
Yasir nawaz
Thanks! Nice explanation. I tried as override command under address family ipv4 and it worked.
mmehdar77
Thanks very much , SunilKhanna
Nice explanation ,
mohsinsalimvs
This post helped me to revive the as-override feature. Thank you very much.
Mohsin Saleem
HairulAhmad5459
This is a good example indeed and it gives out a better understanding of as-override feature with the diagram with the PE and CE configuration.
Well done!
If I may suggest - for the next post, to have a sample ping and traceroute of similar setup , this time without the line as-overide included in the PE configuration as see what happens.
A video on the screenshot configuration could also be helpful in seeing the effect of removing one line .
Keep  up the good work @SunilKhanna !
MysticalTh0r
Hi all,
Does any one know on which IOS release was the support for as-override, without using a vrf, added?
I tested on a 1800 with IOS 12.4 and VRF is needed to be able to add the as-override command. Also tested on a 897 with IOS 15.4 and it worked fine without it.
Best regards.
drumfrodo
This sentence must be a typo. The as-override feature works only for IPv4 and IPv6 address-families (for VRF, and global routing table for newer IOS releases). You cannot use it under VPNv4/v6 address families.
DWAM
Good evening,
on your exemple, your are using public AS (100, 200,121)
I'm trying to do the same think with public AS and it doesn't work (with an ASR1000, there is no change with or without as-override)
Is it available on public AS ? or is it only available on private AS ?
Or is it a bug version ?
best regards.
./DWAM
jpl861
Level 4
Level 4
I was actually doing some lab regarding this and you can actually make this work in IPv4 network as long as the source AS is the same as the receiving AS.
Sample below:
AS15---AS16---AS17
If you advertise networks of AS15 to AS16 then you configure AS-Override to AS17, nothing will happen. The AS-Path in AS17 will still look "16 15".
But if we change it to:
AS17---AS16---AS17
If we advertise the AS17(left) route to AS17(right) with AS-Override on AS16 facing the right-side AS17, the AS-Path will look as "16 16"
So looks like it is restricted in VPNv4 environment.
Korth501
I was having this exact problem where as-override is only working when you connect two AS numbers that are overlapping with each other AS12 - AS13 - AS12. When i change AS12 - AS13 - AS14, the as-override is not working anymore.
