Introduction
This document explains the command show ip ospf traffic in OSPFv2 and OSPFv3. The command show ip ospf traffic helps in troubleshooting the OSPF process in more efficient way by displaying the detailed traffic statistics for the OSPF network.
The OSPF traffic statistics are collected and displayed to include the following information:
  • OSPF Hello input queue and OSPF process queue status and statistics.
  • Global OSPF traffic statistics.
  • Per-OSPF-interface traffic statistics.
  • Per-OSPF-process traffic statistics.
In case of instability in a OSPF network, the OSPF process queue status and its statistical information can help us to determine how much traffic can be sent to OSPF i.e. the amount of traffic handled by and OSPF process can be determined with this output.
Also the OSPF packet header errors and LSA errors statistics help in having a record of different types of errors found in the OSPF packets.
In case of typical local network environments which has slow links and frequent topology changes occurs, you can monitor the amount of  traffic control exchanged between the OSPF process.
Show IP Traffic In OSPFv2
To display the OSPF traffic statistics in a typical OSPFv2 network, use the command show ip ospf traffic
R1#show ip ospf traffic
OSPF statistics:
  Last clearing of OSPF traffic counters never
  Rcvd: 640 total, 0 checksum errors
        617 hello, 3 database desc, 1 link state req
        15 link state updates, 4 link state acks
  Sent: 636 total
        618 hello, 2 database desc, 1 link state req
        7 link state updates, 8 link state acks
             OSPF Router with ID (3.3.3.3) (Process ID 1)
OSPF queue statistics for process ID 1:
                   InputQ     UpdateQ    OutputQ
  Limit            0          200        0
  Drops            0          0          0
  Max delay [msec] 4          0          0
  Max size         2          2          2
    Invalid        0          0          0
    Hello          0          0          1
    DB des         2          2          1
    LS req         0          0          0
    LS upd         0          0          0
    LS ack         0          0          0
  Current size     0          0          0
    Invalid        0          0          0
    Hello          0          0          0
    DB des         0          0          0
    LS req         0          0          0
    LS upd         0          0          0
    LS ack         0          0          0
Interface statistics:
     Interface GigabitEthernet0/1
Last clearing of interface traffic counters never
OSPF packets received/sent
  Type          Packets              Bytes
  RX Invalid    0                    0
  RX Hello      618                  29664
  RX DB des     3                    136
  RX LS req     1                    36
  RX LS upd     15                   1164
  RX LS ack     4                    236
  RX Total      641                  31236
  TX Failed     0                    0
  TX Hello      619                  49516
  TX DB des     2                    148
  TX LS req     1                    68
  TX LS upd     7                    564
  TX LS ack     8                    772
  TX Total      637                  51068
OSPF header errors
  Length 0, Auth Type 0, Checksum 0, Version 0,
  Bad Source 0, No Virtual Link 0, Area Mismatch 0,
  No Sham Link 0, Self Originated 0, Duplicate ID 0,
  Hello 0, MTU Mismatch 0, Nbr Ignored 0,
  LLS 0, Unknown Neighbor 0, Authentication 0,
  TTL Check Fail 0
OSPF LSA errors
  Type 0, Length 0, Data 0, Checksum 0
Summary traffic statistics for process ID 1:
  Type          Packets              Bytes
  RX Invalid    0                    0
  RX Hello      618                  29664
  RX DB des     3                    136
  RX LS req     1                    36
  RX LS upd     15                   1164
  RX LS ack     4                    236
  RX Total      641                  31236
  TX Failed     0                    0
  TX Hello      619                  49516
  TX DB des     2                    148
  TX LS req     1                    68
  TX LS upd     7                    564
  TX LS ack     8                    772
  TX Total      637                  51068
OSPF header errors
  TTL Check Fail 0
OSPF LSA errors
Note: You can view the OSPF traffic for a specific interface by giving the keyword show ipv6 ospf [process-id] traffic[interface-type interface-number]
           Use the command to Clear IPv6 OSPF traffic   to clear the counters
Show IPv6 OSPF Traffic In OSPFv3
R1#show ipv6 ospf traffic
OSPFv3 statistics:
  Last clearing of OSPFv3 traffic counters never
  Rcvd: 18 total, 0 checksum errors
        11 hello, 3 database desc, 0 link state req
        2 link state updates, 2 link state acks
        0 LSA ignored
  Sent: 17 total, 0 failed
        11 hello, 2 database desc, 1 link state req
        2 link state updates, 1 link state acks
            OSPFv3 Router with ID (3.3.3.3) (Process ID 1)
OSPFv3 queue statistic for process ID 1
  Limit            0          200        0
  Drops            0          0          0
  Max delay [msec] 0          0          4
  Max size         2          2          2
    Invalid        0          0          0
    Hello          0          0          1
    DB des         2          2          1
    LS req         0          0          0
    LS upd         0          0          0
    LS ack         0          0          0
  Current size     0          0          0
    Invalid        0          0          0
    Hello          0          0          0
    DB des         0          0          0
    LS req         0          0          0
    LS upd         0          0          0
    LS ack         0          0          0
    Interface FastEthernet0/1
OSPFv3 packets received/sent
  Type          Packets              Bytes
  RX Invalid    0                    0
  RX Hello      12                   480
  RX DB des     3                    244
  RX LS req     0                    0
  RX LS upd     2                    548
  RX LS ack     2                    92
  RX Total      19                   1364
  TX Failed     0                    0
  TX Hello      12                   476
  TX DB des     2                    56
  TX LS req     1                    112
  TX LS upd     2                    188
  TX LS ack     1                    256
  TX Total      18                   1088
OSPFv3 header errors
  Length 0, Checksum 0, Version 0, No Virtual Link 0,
  Area Mismatch 0, Self Originated 0, Duplicate ID 0,
  Instance ID 0, Hello 0, MTU Mismatch 0,
  Nbr Ignored 0, Authentication 0, TTL Check Fail 0,
  Discarded 0
OSPFv3 LSA errors
  Type          Packets              Bytes
  RX Invalid    0                    0
  RX Hello      12                   480
  RX DB des     3                    244
  RX LS req     0                    0
  RX LS upd     2                    548
  RX LS ack     2                    92
  RX Total      19                   1364
  TX Failed     0                    0
  TX Hello      12                   476
  TX DB des     2                    56
  TX LS req     1                    112
  TX LS upd     2                    188
  TX LS ack     1                    256
  TX Total      18                   1088
  Discarded 0
OSPFv3 LSA errors
Related Information
Open Shortest Path First (OSPF) - Home Page
OSPF Command Reference
architmehta
Community Member
Good Explanation
