teegeorg
Check the downloaded SGACL at the egress Edge node.
  1. From the Cisco DNA Center, navigate to the Policy tab.
  2. Click the Group-Based Access Control tile.
  3. Ensure that the SGACl is correctly defined.
  4. From Identity Services Engine (ISE), click Work Centers.
  5. Navigate to TrustSec Policy.
Ensure that the Cisco DNA Center group-based access control information is in sync with the ISE TrustSec matrix.
Run the following command to ensure that the correct SGACL is downloaded from ISE.
show cts role-based permissions
Run the following command to confirm whether the counters for the appropriate SGACL are updated.
show cts role-based counters
