SunilKhanna
Level 5
Level 5
Difference between LAN and VLAN?
A LAN is a local area network and is defined as all devices in the same broadcast domain. If you remember, routers doesn't forward broadcast packets, switches just forward them.
VLAN stands for Virtual Local Area Network. VLANs (Virtual LAN) are a logical segmentation of LANs.In one physical cisco switch; you can create multiple VLANs that connect to different network.
When do you need a VLAN?
You need to consider using VLAN’s in any of the following situations:
    1) You have many devices on your LAN and
want to decrease broadcast traffic.
    2) Users in groups need more security.
    3) Groups of users need to be on the same broadcast domain because they are running the same applications.
Why not to use subnetting for network?
Each VLAN should be in its own subnet. The benefit that a VLAN provides over a subnetted network is that devices in different physical locations, not going back to the same router, can be on the same network. The limitation of subnetting a network with a router is that all devices on that subnet must be connected to the same switch and that switch must be connected to a port on the router.
How can devices on different VLAN’s communicate?
Devices on different VLAN’s can communicate with a router or a Layer 3 switch. As each VLAN is its own subnet, a router or Layer 3 switch must be used to route between the subnets.
Configuration Example:
VLANs are created by number. The two ranges of VLANs are as follows:
    1) The standard range consists of VLANs 1 to 1000.
    2) The extended range consists of VLANs 1025 to 4096.
Every switch comes with the default VLAN 1 and all L2 the ports of switch are part of the default VLAN 1.The VLAN configuration steps for all the Catalyst switches are practically identical
Here I am taking an example of creating VLANs by functions (Sales, Operations and Finance) and more importantly I am expecting users in a particular function able to communicate with other members of the same function/VLAN but not with members of other function.
My first step is to create the three VLANS and then assign ports to respective vlan.
SW#config t
SW(config)#vlan 10
SW(config-vlan)#name Sales
SW#config-vlan)#vlan 11
SW(config-vlan)#name Operations
SW(config-vlan)#vlan 12
SW(config-vlan)#name Finance
SW(config-vlan)#exit
SW#sh vlan
      VLAN        Name         Status        Ports
      1         default        active    Fa0/1, Fa0/2, Fa0/3, Fa0/4, Fa0/5, Fa0/6, Fa0/7, Fa0/8, Fa0/9, Fa0/10,
                                         Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16,Gi0/1
      10        Sales          active
      11        Operations     active
      12        Finance        active
VLANS created namely Sales, Operations and Finance
Now we need to assign ports to respective VLANS
SW#config t
SW(config)#int fa0/1
SW(config-if)#switchport mode access
SW(config-if)#switchport access vlan 10
SW(config-if)#int fa0/2
SW(config-if)#int fa0/3
SW(config-if)#int fa0/4
SW(config-if)#switchport access vlan 11
SW(config-if)#int fa0/5
SW(config-if)#int fa0/6
SW(config-if)#int fa0/7
SW(config-if)#switchport access vlan 12
SW(config-if)#int fa0/8
SW(config-if)#int fa0/9
SW(config-if)#exit
SW#sh vlan
      1         default        active    Fa0/10, Fa0/11, Fa0/12, Fa0/13, Fa0/14, Fa0/15, Fa0/16, Gi0/1
      10        Sales          active    Fa0/1, Fa0/2, Fa0/3
      11        Operations     active    Fa0/4, Fa0/5, Fa0/6
      12        Finance        active    Fa0/7, Fa0/8, Fa0/9
Base Initial configuration:
Related Information:
How To Configure VLANs On the Catalyst Switches
Creating Ethernet VLANs on Catalyst Switches
Configuring VLANs
Martin L
Great summary; thanks for sharing!
